Question about Kodak ESP5250 All-In-One InkJet Printer
I have Windows XP. I was finally able to connect the Kodak ESP 5250 with the USB cable and print. However, I can't get my computer to print wirelessly. The printer is connected to my wi-fi. Do I need to change the driver to go from USB to Wi-Fi? If so which driver and how do I do it?
I had the same issue as well. I had to add the printer manually.
Start>Printer and Faxes
Add device
search for the driver
should be under C:\Program Files\Kodak\AiO\Printer Driver\EKIJ5000.inf
that will install the printer and you will be able to print.
I am still have troubles with the scanning aspect but that will get you printing.
Posted on Nov 24, 2011
  • 3 Answers
I also had a problem with the 5250 disconnecting from the wi-fi network off and on. Called tech support, and they told me my Avira anti-virus software might be blocking the printer's access to my computer, which is also on the network. Went into administration properties of Avira, and in "exceptions" I added the working files of Kodak Home Center, and so far so good. hope this helps
Posted on Nov 15, 2010
  • 132 Answers
In Windows XP:
Start/Settings/Printers and Faxes
Right click /Properties
Check Port tab
If the printer port connect to USB, install another instance of printer, connected to WiFi
Posted on Nov 07, 2010
5250 wont print
Try plugging it in and making sure there was paper, ink and make sure the settings are right. If it won't print wireless then try connecting a usb to your computer !!!!!!
-Hope it helps Anjewel
Oct 15, 2011 | Kodak ESP 5 Printer
I`ve just purchaced a kodak esp 5250 printer.and im unable to connect to my bt home hub wireless . I`ve followed the instructions that came with the printer Can you help.Thanks
You can try to check if you have done the steps here. If everything fails, you might consider getting a USB cable to connect the printer directly to the computer first and use the Kodak Printer Setup Utility to connect. Make sure to install the printer's driver and software using the disc beforehand.
Apr 14, 2011 | Office Equipment & Supplies
Can i print from my computer without the usb 2.0 cable
To print documents from your computer you will need to have it connected via USB. If you just want to print pictures you can load them on to an SD card (or any of the other supported cards for this printer), plug the card into the printer's card reader and print directly from the printer.
If you want to be able to print without using USB you should look into wireless printers such as the Kodak ESP 7250.
Mar 07, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wireless printing
not possible... kodak all in one esp-7 and esp-9 support wireless printing. what u can do is, u can connect ur printer and computer through usb cable and then give a print command from ur computer. be it internet or any document on ur computer. kodak printer will give u high-quality prints,but ur printer does not support wireless printing.
Jul 28, 2009 | Office Equipment & Supplies
Very slow to print when printing from computer
upgrade the firmware of the printer from home center of kodak on ur desktop.take usb cable out from both printer and computer. switch off printer and system and then connect again through usb cable. it will work better.
Jul 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
Kodak ESP5250 All-In-One InkJet Printer Logo
622 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
