Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore bottom freezer 795.75092402 freezer doesn't open
My Kenmore bottom freezer door is stuck and doesn't open. The right side opens slightly but the left is stuck and I can't pull out the drawer.
Please help,
August 2013, Amana Freezer Drawer is stuck closed and will budge.
Solution: Unplug and wait. After a couple of days with no power, the drawer would pull open slightly on the right side. After 4 days and a lot of water on the kitchen floor, we pulled it open. A malfunctioning ice maker flooded the freezer with water creating a solid block of ice!
Posted on Aug 04, 2013
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
The right door of my Kenmore side by side
You may have a broken cam riser which is located at bottom hinge. Compare the 2 hinges with the doors open. The right side is probably missing 1 piece.
Feb 16, 2010 | Refrigerators
Freezer door opens each time we close refrigerator door
This is an easy one to fix - at the bottom of your unit you have 2 adjustable wheels you can turn to raise or lower the unit. What you need to do is turn those clockwise which will raise the front - what you want is to have it slightly tilted to the back. As a test you can open your door 45 degrees and leave it - it should be able to close on its own.
Sep 25, 2009 | Kenmore Refrigerators
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door on GE side by side stays open slightly at top
i have kenmore side by side model 52552100 and the ice maker will not send ice thru the door. I is not even making any sounds when I push the button dispense. Can you duplicate this problem
Apr 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Freezer door will not open!
Something has caused the gasket material to adhere; either the material from which the gasket is made or a spill of something sticky that has dried. If you can get a crack to open anywhere, slide a butter knife into it and wobble or rock it while applying a little pull to the door.
Once opened and cleaned, treat the seating area for the gasket with silicone spray from an auto parts or home improvement store. I wouldn't spray it on the surface but on a clean rag to wipe the gasket seat; the volatile carrier of the spray may damage some paints or plastics.
Sep 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
803 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Jude24
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
