Question about Maestro Lutron MAW-603-RH 3-way 600 Watt Preset Package
The lights on the dimmer flash and/or brighten and dim on their own. How do we fix this?
    Novelist:
  • 107 Answers
For 100% certainty, I would call Lutron's tech support at 1-800-523-9466. They're available 24/7 and can probably troubleshoot it more effectively than through this text-based dialogue. However...
I have three guesses...
1) Check the minimum load. The minimum load for those products is about 40-Watts. If there isn't enough lamp wattage pulling electricity through the dimmer, the dimmer may not have enough juice to keep itself powered up... and then shut down (hence any flashing you may see). If the issue only happens when the lights are at full (or close to full) brightness, then that's most likley your issue. To solve, either increase the lamp wattage, or replace with a dimmer that contains a neutral wire such as the MAELV-600M.
2) Check the load type. The dimmer's are rated for incandescent & halogen. If these are LED or CFL lamps, you are going t see issues. For dimming performance, either convert the lamps to incandescent / halogen, or investigate their new Diva dimmer for CFLs & LEDs: DVCL-153P-
3) If neither of those solve the problem, the next guess is to check the wiring. I wouldn't expect this to cause any "flashing" but in the wiring circuit, each device had a blue screw attached to it, and you need to make sure that the blue screws are wired/connected to each other and ONLY to each other - otherwise "automatic" dimming can take place.
But again, the only way to be certain is to use their tech support. I highly encourage you to use that.
Posted on Nov 09, 2010
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
Dash lights come on with the headlights then shut off
Do you have a dimmer for interior lamps? Like a rheostat, a little wheel that you turn up or down to brighten or dim interior lamps. Usually the instrument cluster lamps brighten and dim the same way.
Can you brighten and dim the other interior lamps?
Apr 17, 2016 | Cars & Trucks
How do I brighten clock light it's very dim?
Is your clock part of radio assembly? There is usually a dimmer control for interior lamps, you rotate it to brighten or dim interior lamps--dome--instrument cluster--radio illumination. The same thing should work for the clock. If clock is part of radio assembly, I guess you can remove radio and dig into it, see if you find the wiring for clock illumination.
Apr 16, 2016 | 2005 Buick Rendezvous
When i turn headlights on...radio lights go out..they come on when i turn dimmer switch..but then dome lights wont go off...tried it on all different positions...2008 patriot
It sounds to me like you may have a defective dimming switch. Are the instrument cluster lights working as they should? Do they dim/brighten with the dimmer? If the instrument cluster is working OK, then it could be an internal problem in the radio unit itself. Your panel lights are computer controlled. The processor in the instrument panel controls them. It uses a digital signal to "tell" the radio to either dim or brighten its lights. If the radio is failing to do so, the radio is the most likely cause since the lights work on "full power" which is also commanded through the same data lines. (this eliminates the signal from the cluster and the connection through the data lines.)
May 23, 2011 | 2008 Jeep Patriot
Whenever i open my head light at night, the dashboard light gets dimmed. I can't see my speedometer.
Theres a control below the light switch that will brighten the dash lights when in dim
Jan 21, 2011 | Ford Taurus Cars & Trucks
Overhead display too dim to use - can it be brightened?
I think it should brighten to the max with your dash light dimmer....You could put brighter bulbs in it.Hope this helps.
Aug 13, 2010 | 1993 Jeep Grand Cherokee
No dashboard light in 2001 Suzuki Aerio
most dash lights you can brighten or dim by the light switch.
Mar 09, 2010 | 2001 Suzuki Xl 7
2005 Chevy Trailblazer. We recently had the gas
you need a new altinator if ur head lights dim and u are loosing power!!
Sep 28, 2009 | Chevrolet TrailBlazer Cars & Trucks
Dash lights come on when dome light goes out
The only possible location I can think these circuits cross is at the headlight switch.The dimmer rheostat or the wheel you turn to dim and brighten your dash lights also should turn on your dome light so I think maybe a new headlight switch assembly or rheostat should fix tour problem
Aug 15, 2009 | Chevrolet Lumina Cars & Trucks
Maestro Lutron MAW-603-RH  3-way 600 Watt Preset Package  Logo
247 people viewed this question
Top Maestro Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
