Question about Nikon D50 Digital Camera
Help black line on bottom of picture.
Recently I have been having a problem with my Nikon d50. Every time I take a picture I get a black thick line going across the bottom of it. Dosw anyone know why this is happing or what I may be able to do to get this problem solved. thanks
nikon girl
  • 2 more comments
  • shadeofgood Aug 10, 2008
    I am experiencing the same problem. I have the Nikon D50 with a 18/55 mm lense. I notice the bottom half of all my pictures turn black when I set the camera to the "Auto" setting. I notice this problem is noticeable when I use the lense to zoom in. It is less noticeable when I zoom out.
    When on Landscape, it is no problem. If anyone has the expertise to explain the problem and bring forth a solution, please let me know. I am extremely good with computers, but I need more knowledge to fix this camera if it is a problem.
  • Locobros Nov 14, 2008
    We have the same problem and took it for repair but they had no idea what it was and the black line is getting bigger and bigger like it is overtaking the picture. My daughter needs this for her school and I can't afford a new one. If anyone knows how to repair this or where to take it let me know. Locobros@aol.com Thanks Marianne
  • Cylon_X Nov 27, 2008
    I can report the exact same problem with a D80. Interestingly, I only get it when I'm in mode "M", it works fine in the automatic modes.
  • Jason Adlard May 11, 2010
    if it shows up on the LCD only, its likely a faulty screen
    if it shows up on pictures its likely a CCD or associated circuitry problem, mirror or shutter problem
    can you post an example
After a bit of experimenting, I have found a solution that works in my case. The problem was the shutter speed. At 1/200 I got the black line on the bottom of my pictures, but when I tried it at or below 1/100 it was gone. Hope this helps.
Posted on Nov 27, 2008
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Nikon d50 takes black picture w/ lens cap off
Sounds like a settings issue please provide more information such as what is your camera set at; ISO, Shutter speed, F-Stop & how are you using it, manual mode. Aperture priority, shutter priority or Auto? I would need this info to further direct you in trouble shooting your issue.
Apr 12, 2014 | Nikon D50 Digital Camera with 28-80mm Lens
Blue line threw d50 pics
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | Nikon D50 Digital Camera
Nikon D50 Just Quit Taking Pictures!
The imaging board is one of the two boards on the bottom of the camera. however, black images are usually a result of a bad image sensor itself (the 'CCD'), and the cost to replace that is far more than what your camera is now worth (if it is even still available)
Jun 02, 2012 | Nikon D50 Digital Camera with 18-55mm Lens
How do you make the ML-L3 wireless remote controller for Nikon D7000 work?
Press the release mode dial lock release and turn the release mode dial to the remote control position.
Full details are in the "Release Mode" section of the manual (page 77 in my copy).
Feb 03, 2011 | Nikon ML-L3 Wireless Remote Control...
I use my Nikon D50 for work and I am now required to have a date on all my pictures. Does the Nikon D50 have a facility to do this? If so how is it done?
All digital pictures include Exif Data which shows when the picture was taken and using what camera. Most photo edit programs like Picasa etc will show this data very readily. The times of printing a date onto the photo are gone, though there may be a setting to do it on your camera.
Jul 20, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon coolpix s600 black screen or lines after taking a picture
Black screen after clicking a picture means aperture motor not working or lens flexible circuit damaged, it has to be checked by expert technician & is replaceable part.
Sep 30, 2017 | Nikon Coolpix S600 Digital Camera
I have a Nikon D50 black image on bottom of screen what is causing this problesm
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
Jan 21, 2010 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
633 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
