Question about Vacuums
How to change time zone skyscan model 38229-1 atomic clock
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: Model 31320 SkyScan Equity Time
You press and release the mode button, then press the adjust button. This is what the instructions say to do. However, I see that you don't have an adjust button listed. I would try pressing and releasing the mode button, then pressing the ZONEDATE button and see if that will do it.
If this works, please place a vote for me. Thanks,
Handie Andie
Posted on Mar 27, 2011
jyackle5
  • 8197 Answers
SOURCE: Have a Sharp Atomic Wall
  • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
  • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
  • 3 Wait 15 minutes. The clock should synchronize automatically.
  • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
  • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
  • If that does not work try this.
    1) Pull the battery and wait a few minutes.
    2) Put battery back in - time will set to 8:00 (or possibly something different). 4, 8, or 12
    3) After it stops spinning, Press the "leverage button" (just above an to the left of the time zone buttons and battery) and the clock hands will spin. (It does not look like a button, its a lever)
    4) Release the leverage button when the correct time is reached.
    5) Supposedly, this new time will track correctly and keep accurate time.
    Posted on Jun 13, 2011
    Need manual for Travel Companion Model S1500 Alarm Clock
    Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
    1. Power source
      • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
      Changing the time
      • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
      Setting AM/PM
      • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
      Setting alarm time
      • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
      Turn alarm on
      • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
      Music options
      • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
    Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
    Sep 22, 2011 | Vacuums
    My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
    Hi lufberg,
    I see you need help with your radio controlled clock.
    Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
    Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
    I hope this will help.
    Thank you for choosing Fixya,
    mvincentc
    Jul 04, 2011 | Vacuums
    My oregon scientific projector clock keeps changing time, I think it might be something to do with the time zone. I do not know what a time zone is?
    A time zone is section of the country that adjusts for daylight savings time. The United States is composed of four time zones - Eastern, Central, Mountain, and Pacific. Each county is assigned to one of the four time zones. See the attached map to see which time zone you are in. Then you must set up your clock to match that time zone. bblue1967191.jpg
    May 03, 2011 | Vacuums
    Model 31320 SkyScan Equity Time Clock -- it did not change with DST but I cannot figure out how to manually set the time. Back of clock shows 4 long...
    Handie Andie
    Mar 27, 2011 | Vacuums
    I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
    For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
    There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
    I hope this helps.
    Feb 03, 2011 | Vacuums
    I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
    The Sio/Scan Atomic clocks should automatically set the time and date.
    Place the clock in a window facing towards Colorado and give it 24 hrs to update
    If that fails here's the web site for them:
    http://www.skyscaninfo.com/content/manuals.html
    Jan 03, 2011 | Vacuums
    Manual for Centrios atomic Clock model 6316008
    Go to the Source.ca look for this clock, model number.Go to the parts section and download the instructions in french or english.I just looked so i know this works.
    Nov 04, 2010 | Vacuums
    I have a Silicon Scientific Atomic Projection Clock I don't have a manuel for the clock was wondering if you could walk me through how to set
    I have the instructions that came with the Silicon Scientific Atomic Projection Clock and was going to attach them as a PDF but it doesn't look like it's allowed here. If anyone know how to do that let me know.
    Sep 06, 2010 | Vacuums
    Vacuums Logo
    74 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
