Question about GE AJCQ08ACB Air Conditioner
Ac smells and i took the ac out and it had no signs of water. ac doesn't seem to be draining
    Problem Solver:
  • 12 Answers
Do wet service then check the rated amps or gas pressure
Posted on Nov 09, 2010
Express van dead animal smell in vent
had this come up before seems that ac drain was way clogged off and water from ac soaked up to the air filter in there , yuk!!! it grew mold and wow it stunk kinda like a skunk, very bad 4 you to breath that as well , cleaned it all out with disenfectant and fixed ac drain (made it bigger too) wow what a job had to remove entire dash to access it
Aug 30, 2014 | Cars & Trucks
I have a leak on the drivers side of floor board. under carpet it gets really wet not so much on top of carpet. help. I took it to a glass expert. They could not get it to leak at all. There was a little...
resealing the windshield should solve the problem i like to recommend safe lite auto. if there is no sweet smell in the car then it is the windshield. if it is sweet smell this would be a heater core.thanks for your question!
Apr 16, 2009 | 1996 Buick Skylark
Does my 2009 ford explorer have a cabin air filter?
I don't list a cabin filter available for 2007 - 2009 Explorer.
Usually the smell is trapped water in the hvac box due to a plugged drain line. The water is supposed to drain onto the ground under the truck when the ac is on.
Jul 29, 2013 | 2009 Ford Explorer
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
Our ac unit is making a loud noise and there is water coming into the house via the vents. we cleaned out the vent and took some of the water out of the middle pan and the outside pan, and it doesn't...
My recommendation would be to have some one knowledgeable in refridgeration come in and take a look. You make have more than one problem going on. However the water build up can be due to a plugged drain line. Try using a wet and dry vac to clean the drain line . the fan noise may be the fan motor bearings. If this is the case you can remove the fan and possibly have bearing installed but most likely will need to replace the fan motor
Jul 07, 2011 | General Air Tools & Compressors
Water is leaking from the ac vent in the inside of our rv. We took the cover off and it looks like water is leaking from some kind of hole in a silver box. How do you fix this?
Water is NORMAL in the process of A/C, works like glass of icewater, water vapor condenses when chilled...This condenced water should be drained outside, usually by a black drain hose. you cannot block the water or the system will fail, smell bad, and damage the evaporator (similar in function to a heater core, but for AC).
Oct 15, 2010 | Dometic Rooftop RV Air Conditioner
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
AC Smell
This usually means that the drain holes are clogged, which causes water to collect where it shouldn't. In a short time, it becomes stagnant and smelly. You'll need to remove the cover from the a/c and clean out the drain holes and probably also the pan underneath it. Don't use anything sharp or metal though.
Jun 25, 2008 | 1999 Toyota Tacoma PreRunner
GE AJCQ08ACB Air Conditioner Logo
47 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
