Question about Westell Wirespeed ProLine 6100 Router (C9961001100)
No internet My new laptop recognizes my wireless router (Netgear), but I can't get internet access. I can login to another network, but not mine. I have a Westell B90-610030 modem/router from Bellsouth. I don't have the Westell CD and couldn't download the software from the internet (upg file.) Not sure if this has anything to do with it. Would appreciate your help. Thanks, Alex
  • 4 more comments
  • Amm342 Jun 16, 2008
    I do have a connection if I connect it directly to the Westell. I also get a signal from the Netgear, although it says local only (no internet.) It seems there's a conflict between the Westell and Netgear.
    I know how to get to the Netgear page, but don't know what to do from there. Could appreciate some extra help.
    Thanks, I think we're getting closer to fixing this thing.
    Alex
  • Amm342 Jun 18, 2008
    http://192.168.1.1
    Netgear WGR614 v6
    Thanks,
    Alex
    Still no internet...
  • Amm342 Jun 20, 2008
    I connect directly to the modem, and I don't need a username and password. Both the IP address and DNS are set to get dynamically from ISP.
  • Amm342 Jun 23, 2008
    Thanks, I dusted out an old Linksys router and set it up. I was having the same trouble, but found a blog that helped me solve the problem.
    Thanks for your help.
    Alex
  • 298 Answers
Do you have a computer that can get online through the router via wired connection? If not then the router is not yet configured properly. Give me an update on this so i can give you more options on how to rectify this concern.
Posted on Jun 15, 2008
  • 5 more comments
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 16, 2008
    that is right. It seems like we need to change the address of either the modem or the netgear router. becuase your netgear and westell uses an ip address in this range 192.168.1.x.
    do you know how to access the setup page of your netgear router? if you do you change the netgear router address to 192.168.2.1. If you need more details on how to do this. just reply to this post.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 17, 2008
    What address are you typing in to get in to the netgear's setup page?
  • Jeffrey Pedimonte
    And kindly include the model and the version of your router to make sure I can give you the exact steps on how to chage the router address of you netgear.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 18, 2008
    You need to get in to the setup pag of your netgear setup page.
    Then on the letft hand side look for the LAN IP Setup its under Advanced. then change the LAN IP address to 192.168.2.1 And Make sure the the dhcp server is in the same range.
    If its 192.168.1.2 then changet the 3rd octect to 2 same as the LAN IP.
    The save the settings or click the Apply button. then turn off the router for 30 sec plug it back in and check if you will be able to access the internet with your computer.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 19, 2008
    How do you connect to the internet through the modem?
    Do you need to put a username and password to get online through it or does it just automatically get online.
    What is the setting of your router's basic settings? Is the Internet IP Address set to Get Dynamically From ISP? Make sure that the DNS is also set to Get Automatically From ISP.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 23, 2008
    Okay I dont see why you cant still connect to the internet. Let's just try to double check how the router and your modem is setup. Let's start with the physical connection.
    the westell modem should go to the internet port of your netgear router and the computer/s should go to one of the ports labeled 1,2,3, or 4. The lights that should be lit on the router should be the power solid green/blue, port where the computer is plugged in to, the wireless light and the internet light should be lit and sometimes flashing. Now the router settings should be Autoamtically obtain the Internet IP Address From ISP and same with the dns. You router address must also be set to 192.168.2.1. If you still cant go online turn off the router,modem and wired computer. Wait for 1 minute and turn on the modem first, wait for the lights to stablelize and turn on the router, once the power is soild on the router then turn on the computer. If you will still not be able to get online then its either the router has a problem or you can try to set the modem to bridge mode (your isp can help you do that) and set the router to PPPoe. But if still fails i suggest to contact netgear tech support to test the router that you have.
  • Jeffrey Pedimonte
    no worries
Not able to connect to my netgear login. I clicked on a button and now it wont connect. Any Suggestions
You need to configure the Netgear wireless router first.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 13, 2013 | NetGear Computers & Internet
Connect Nokia C3 to Netgear router
http://192.168.0.1
Mar 18, 2013 | NetGear WGR614 Wireless Router
What is the code for netgear WGR614v7 to enter to a laptop for wireless wifi?
http://192.168.0.1
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Jan 28, 2013 | NetGear WGR614 Wireless Router
My laptop cant connect to the internet
http://192.168.0.1
Jan 21, 2013 | NetGear WGR614 Wireless Router
Wifi works and all but keeps having my two phones put the password in every half and hour. I don't have the disc for it so can't really set it up just connected it to my charter modem.
Try this please:
  1. eHow
  2. Internet
  3. Wireless Internet & Network Hardware
  4. Netgear Wireless Routers
  5. How to Access Netgear Wireless Router Settings
X Must See: Slide Shows
How to Access Netgear Wireless Router Settings Xno-user-image.gif Ryan Bauer
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
72955587_xs.jpg Wireless routers connect computers to a network without the need for network cables.
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryptionicon1.png," "Network setup details" and "Passwords" can be customized.
Other People Are Reading
Instructions
    • 1
      On a computer that is connected to the routericon1.png with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    • 2
      Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
    • 3
      Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
Read more: How to Access Netgear Wireless Router Settings ' eHow.com http://www.ehow.com/how_4913660_access-netgear-wireless-router-settings.html#ixzz2H3QQJGxn
Jan 04, 2013 | Computers & Internet
Set up wireless
Netgear wireless router settings must be changed using the router's web-based interface. Any computer on the network can be used to access it. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
There are a few different variations of login credentials. Though these steps will use the details that work for the most common router models, the alternate login details that other models of Netgear wireless routers use will also be included.
Things You'll Need
Computer connected to the network
1 Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" (without the quotes) and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
2 Enter the username "admin" (again, without the quotes), and the password "password" in the appropriate fields, then click OK to login. If that password fails, try "1234," "Password" (with a capital "P"), or "admin" until you are greeted with the settings screen.
3 Make any required changes to the settings. Under security, it is possible to specify a new username and password for added security. Once you are done, close the window, and the system will automatically log you out.
Tips & Warnings
Always secure a wireless network to prevent outsiders from being able to change your network settings.
Jan 09, 2012 | NetGear RangeMax Computers & Internet
NI need a new password fonetgearnet my wifi-internet. We have secured internet originally but now that I have a new laptop I need to connect it with our secured wifi. The problem is I can't find the...
You can reset the Netgear back to the default settings, then you can change the login password and setup the wireless settings again.
Power up the Netgear and press and hold the pinhole RESET button at the back of the wireless router until the LEDs flash. Open a browser and enter the Netgear's configuration URL
http://192.168.0.1
The defailt login = admin
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 21, 2010 | NetGear WGR614 Wireless Router
I DONT KNOW HOW TO PUT MY NETGEAR ROUTER THROUGH MY LAPTOP , SO I CAN HAVE WIRELESS INTERNET ACCESS
u will need RJ45 CABLE (normal ethernet cable, labelled cat5e)
plug one end into laptop network connection other into laptop
login address will be (netgear) details will be under router
http://192.168.1.1pi
or something like that.
login id: admin
password: password
if u cant login then, press reset button back of wireless router, will need to do that with pen or pin?
once logged into the router, use the setup wizard and the the rest is self explanatory.
once setup is dne, with SSID and password, then plug the cable from laptop, in back of the internet modem coming into ur house from ur supplier....and ur ready to surf the web.
find your new wireless network using the laptop and insert the password....
Oct 10, 2010 | NetGear WGR614 Wireless Router
Laptop shows connected to network via netgear router wirelessly but wont connect to internet
I would recommend checking that your laptop is set up on the access list in the router. Login to the router and check the settings.
May 26, 2010 | NetGear WGR614 54Mbps Wireless Router...
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Computers & Internet Logo
249 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
