Question about Amana NDE6800AYW Electric Dryer
Dryer is not working it's not heating up and we just put a new heating element in it Any idea?
    President:
  • 1,218 Answers
Good day,
The first thing to check is the voltage on the back of the machine. Be careful. That's 240 volts. It should read 120 volts from one end to the center terminal. The same for the other side. Across the 2 ends it should read 240 volts. Correct as needed. The motor runs on 120 volts so it can run even if one side is out.
From the front, you have a mired of limit and control thermostats, fuse links ect. They are located on the heat tube and around the blower housing. They should test at at zero ohms with the machine unplugged. The most common one to fail is the thermal fuse. it looks like this.
You can go to http://www.appliancepartspros.com
To see a breakdown.
In addition, there is the timer and heat selector switch but they rarely fail.
Posted on Nov 07, 2010
I replaced the element in my 80 series dryer. Now the element continues to heat without the dryer running ! Any ideas?
Some were u got what call short to ground. It problem the motor are u got a wire touch the dryer cabin if u don't know how to check it u might won't call for service are when u put the element back in it case one of element heating coil is touching the case.
Apr 03, 2015 | Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heat elament is out
  1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Unscrew the screws holding the element in place and pull it out.
  5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Sep 23, 2009 | Washing Machines
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
Jul 15, 2009 | Kenmore Dryers
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Need to change heating element on my kenmore dryer
they are pretty simple to change out.the heating element should be easy to access and once you get the old one out you simply put the new one in in its place. depending on the machine the heating element should be in the back wich means you have to take the top off the dryer to access it and then you will see what you need to do from there,its only held in but 2 or 3 screws.
Jan 08, 2009 | Kenmore 63942 Dryer
New Element, still no heat
Jan 07, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Amana NDE6800AYW Electric Dryer Logo
78 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
