Question about Refrigerators
U-Line Wine Fridge 2175WC: Intermittently displayed "Er" instead of temp set point and control panel did not respond to touches but temperature seems ok and compressor sounds as if it is running only occasionally and normally. Called U-Line but they told me I would need to call someone out to diagnose which I don't want to do as prob not sealed system problem so not warranty covered. Unplugged overnight and have not seen Er on display for several days but the control panel still does not respond to touches so cannot access Factory Control Mode with Up arrow and three presses of light to see what that says. Any suggestions as to cause and fix?
SOURCE: new GE profile refrigerator bottom
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Posted on Aug 31, 2008
SOURCE: GE French Door Control Panel LEDs Off if Fan is on.
Solved my problem. Replaced the motherboard. P/N WR55X10552. Purchased on Ebay, $70.00
Posted on Nov 17, 2008
  • 205 Answers
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Posted on Oct 14, 2009
SOURCE: LG LRFD25850ST gives ER CO code on door
Good call Cooltech! My new LG "open box" deal from Best Buy must have been delivered once before. I hauled it home, plugged it in and Er CO was on the display. The doors must have been removed to get through tight spaces, exposing the bundle of wires and connectors under the left hinge cover. One wire had been repaired with a crimp lug, wire cut too short, and the crimp was no good. I soldered the connection and added 2" of wire so it wouldn't be stressed. Works!
Posted on Mar 17, 2010
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
our problem was fridge door alarm ,no cooling ,light out ,Freezer ok. Turned out to be the fridge side of the fridge/freezer door switch . Removing the double switch (it's a press fit) enables the fridge fan to work while waiting replacement. Replaced with new double switch now we have a light too.
Posted on Jan 10, 2011
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Jan 18, 2009 | U-Line Refrigerator Ice Maker
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Feb 16, 2008 | Freezers
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
Touch Temperature Controls not working
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Apr 09, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
