Question about Gevalia CM-500 12 Cup Coffee Maker
Model C-60A Circuit board has gone bad - Gevalia CM-500 12 Cup Coffee Maker
My Samsung microwave model C139STFC got no display but is working fine
If it is an led display, it might have a display driver integrated circuit that has gone bad. More likely, though the driver might be part of the microprocessor. Either way, you'll either need to have an electronics technician fix it, or replace the circuit board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 26, 2016 | Samsung Microwave Ovens
Which relay/fuse controls the power windows?
Visual Inspection Chart Mechanical Electrical
  • Door window regulator and motor
  • Door glass top run
  • Door window glass
  • Loose, corroded connectors
  • Circuitry
  • Window control switch
  • Battery junction box (BJB) fuse(s):
    • 1 (60A)
    • 3 (60A)
    • 11 (50A)
  • Smart junction box (SJB) fuse(s):
    • 7 (20A)
    • 27 (10A)
    • 30 (10A)
  • SJB circuit breaker 10 (30A)
  • SJB rear window defrost relay 1
  • Relay center box 1 rear window defrost relay 2
  • Delayed accessory relay
  • Battery saver relay
  • Rear window defrost grid
Apr 23, 2016 | 2005 Ford Taurus
How to fix led tv thats not powering up properly
Most likely some capacitors on the inside circuit board has gone bad. Do a search on YouTube for some tutorials on how to replace. Type in your make and model too.
Feb 08, 2016 | Televison & Video
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Blue tint on movie
Not sure of you make and model but this can be the HDMI cable has gone bad or the connection is bad. Try cleaning the player and make sure all connections are tight. These are not worth taking them to be repaired if it is a circuit board issue. It is cheaper to replace than repair.
Mar 25, 2012 | Televison & Video
The circuit board is showing a F10 on it.
Hi
Thanks for using FixYa. F10 error in your Kenmore means temperature runaway. This issue is caused due to failed oven temperature sensor and/or the control board that has gone bad. To check what has gone bad you’ll need to take off the rear panel off the oven and test the sensor which is located behind this panel. If the reading is more then 1100ohms then it should be replaced, if the sensor tests fine then it is the control board that has gone bad and should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
Aurora Papaer Shredder circuit board problem?
It just sounds like a paper dust problem.
use canned air to completely clean all sensore.
Oct 23, 2009 | Office Equipment & Supplies
Genie remotes stopped working
The receiver can go bad and that would stop all remotes from working. The wall control would still work because it does not use the receiver.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
75 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Jim Green
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
