Question about Frigidaire Affinity AEQ6000WH Dryer
My frigidaire front load dryer has no heat - Frigidaire Affinity AEQ6000WH Dryer
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 07, 2010
Jimster
  • 240 Answers
SOURCE: Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Posted on Sep 09, 2007
  • 146 Answers
SOURCE: front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Posted on Dec 22, 2007
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
  • 7 Answers
SOURCE: dryer beeps when it isn't running
sounds like the control board, is there any codes displayed?
Posted on Oct 16, 2008
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
What could it be
Hello Reese,
I see that you're having a Problem with your Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer. I see that the washer will not work until dryer is turned on and the dryer will not heat. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the appliance is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back on and try to restart it. If you are still having trouble with the washer not working until dryer is turned on and the dryer will not heat. I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 20, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Front load frigidaire dryer does not heat and runs for a few minutes then shuts off and all the light flick off and on
Checkout the heating element. If it is open the electronics of machine may be programmed to turn it off and blink lights.
Nov 23, 2013 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My frigidaire dryer squeaks
Spray some good lubricant on the tires and belt idler. Solves the issue 95 % of the time. If not ,try a funnel attached to a piese of garden hose to pinpoint the source.
Dec 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not getting hot
Bad thermal fuse or heating element
Nov 02, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
No heat
Check your breaker box, or fuses. A dryer will run but not heat if one fuse is bad.
Sep 28, 2008 | Frigidaire FEQ1442ES Electric Dryer
Front load dryer
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Affinity AEQ6000WH Dryer Logo
367 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
