Question about Nordic Track Exercise & Fitness
Can you provide the ifit activation code for the nordictrack asr 1000 elliptical?
4 Suggested Answers
  • 5 Answers
SOURCE: I have a C900 nordictrack. The ifit live module
I just had the same problem. Of course tech support is closed so I sent an email. We'll see if they get it fixed tomorrow.
Posted on Feb 25, 2011
roadtech7
  • 297 Answers
SOURCE: I have a Nortictrack Exp
The activation number is 1-866-608-1798, You will need the model and serial number to get it activated.
Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 02, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Posted on Jun 11, 2012
Nordictrack elliptical asr 700
Hi There,
There may be a problem with a power wire inside the machine.
Ring Icon Fitness to repair.
Aug 24, 2014 | Exercise & Fitness
Display lights up but no information displayed
did you change the batteries or are you using a power cord?
Mar 25, 2014 | Nordic Track Nordictrack Ack Asr 630...
What is the activation code?
https://www.ifit.com/me/settings go to this page for activation code from ifit.
God bless you
Jun 06, 2013 | Nordic Track NordicTrack T5.5 Treadmill
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Skips when running on nordictrack 1000
Run the software calibration for diaignostic, troubleshooting, and fix it.
However you see the video and adjust it.
Sep 24, 2012 | Nordic Track Nordictrack Asr 1000 cwl...
God bless you
Jun 10, 2012 | Exercise & Fitness
How to the update ifit firmware
go to www.ifit.con directly
sincerely.
ernesto cuadra
managua,nicaragua c.a.
Dec 11, 2011 | NordicTrack Treadmill
I have a Nortictrack Exp 1000 XI, with owners manual, but no Ifit activation code, is there any way to get that? Thank you in advance for your time, Sincerely, Mrs. Breen
Hope this helps.
Aug 16, 2011 | Nordic Track Nordictrack Exp 1000...
It seems a belt has slipped off nordic track asr 700. How do I remove cover to get a better look?
You have to pull the upper console and console tower before removing the panels, If you have access to a owners manual I suggest looking at the explodes parts it will give an idea of disassembling the unit. If you need a manual the go to iconservice.com click on manual input this info NORDICTRACK ASR 700 ELLIPTICAL (NTEL00607)
May 21, 2010 | Exercise & Fitness
Exercise & Fitness Logo
1,390 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
Craig Butler
Craig Butler
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
