Question about Samsung SyncMaster 940MG 19" LCD Monitor
My SynchMaster 940MG won't turn on. I'll hold on the power button on the bottom, and it turns green every 5 seconds, but won't turn on. Please help.
5 Suggested Answers
  • 1003 Answers
SOURCE: Blinking blue light and no display
I WOULD REMOVE REAR PANEL AND LOOK FOR A MASTER RESET BUTTON OR A BLOWN FUSE ALSO CHCEK
YOU AC ADAPTOR TO SEE IF IT IS WORKING FIRST.
Posted on Jan 16, 2008
budmrtn
  • 11361 Answers
SOURCE: I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 18, 2010
  • 80 Answers
SOURCE: samsung 940mg won't power up
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following site
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Posted on Jun 10, 2010
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
My Nokia 6790 won't turn on, what's wrong with it?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jun 20, 2017 | Nokia 6790 Surge Cell Phone
How do I reset the Waste Ink Counter on my Canon iP90 printer?
HelloFollow these steps
1. Turn off the printer...press and hold the resume/cancel button... then press and hold also the power button..
2. Release the resume/cancel button while holding still the power button.
3.(While still holding the power button)...press three times the resume/cancel button
4. (After pressing the resume/cancel button three times)...release the power button
5. Wait for a couple of seconds.. when the led stops blinking and turn green..Press the resume/cancel button four times.
6. Press the power button...some functions will be perform before the printer return to menu selection mode..
7. Turn off the monitor wait for 5 seconds, then turn it on and try printing..
Hope that solve the waste ink absorber in your printer..
If you find this solution helpful..would you be kind to rate this solution and vote for this on the help below..thanks..
Jan 05, 2011 | Office Equipment & Supplies
My Pandigital 7' EReader won't turn on even when I charge it. I had it on playing a lullaby for my kids and now it won't turn on. Please help.
plug it in then push power+volume up for 30 seconds or until a message appears for 1 second easy to miss so dont blink until you see it then let go and press power button until it boots
Dec 19, 2010 | PANDIGITAL 7" Digital Photo Frame With...
I need to reset my Canon Pixma MP160 after replacing ink cartridges. The display flashes E and 5. By pressing the black or color buttons and holding for 5 seconds does not rectify the problem.
Hi there not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Apr 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 24, 2009 | Televison & Video
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
Lone99star
Jan 21, 2009 | iLO 3200 32 in. LCD Television
Samsung SyncMaster 940MG 19" LCD Monitor Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
