Question about Tascam 2488 Portastudio Multitrack Recorder System
On boot up, i get system error - any ideas?? - Tascam 2488 Portastudio Multitrack Recorder System
  • 4 Answers
Does it say , cannot boot, hdd......check h/w???Had the same troubles..Tried new hard drive, wasn't the problem...Just for kicks, plugged in a new Cd-rom.....Shazammmmmmmmm!!That's was MY PROBLEM....It BOOTS UP NOW......Carl -in -Louisiana.......Post me back if it helps..
Posted on Nov 17, 2010
PC stops booting after USB devices are enumerated
Firstly when you restart your computer, does it dispay an error message reading, THE SYSTEM HAS RECOVERED FROM SERIOUS ERROR.
Apr 05, 2013 | EliteGroup GeForce6100PM-M2 (V3.0)...
Have an Abit A17 motherboard that stops booting with a check sum error. Code on the digital readout is either IA or 1A, neither of which is in the manual. Any idea about this?
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
Jul 15, 2011 | Abit AI7 Motherboard
Reformat and install operating system. After a few days it can't find operating system. Have done thsi about three times and continues to do the same thing. Bad HArd Drive??
Its very possible that you have errors on your drive but have a look in your bios settings to make sure that the hard drive in question is still set as the boot drive, sometimes the cd drive may be set as first boot device, changing the first boot device as your hard drive will pretty much always speed up your boot time apart from anything else. Try this to see if it helps, or after the next re-install (if required) check the event viewer to see if any drive errors are being reported. Another thing which could help, again after a re-install if the first ideas dont work, is to right click the boot drive and go to properties, in here select the tools option and select check disc, the pc may need a restart to allow it to check the disc.
Hope this helps
May 06, 2011 | Computers & Internet
Having dropped my Samsung R530 (nothing obviously broken), when I try to stsrt it it is coming up with the message:- "Boot From AHCI CD ROM: Operating System not found" Any ideas?
Hi tony prother,
"Boot From AHCI CD ROM: Operating System not found" error is because the system is booting the CDROM of the system and its not detecting an installed Operating System. You need to check if the system still detects the Hard Drive of your laptop on the Bios page. To go to BIOS reboot the computer and tap F2 on the system and on the bios page check if the hard drive is detected then go to then BOOT Tab select the hard drive as the first boot priority and reboot the system.
If the hard drive is not detected it might be damage, you can get intouch to a local tech to check and backup the files.
Thanks for using Fixya.
Jan 28, 2011 | Samsung R530 (NPR530JA02US) PC Notebook
Error 2000-0142
Hi there!
The error code you have there means that the Drive Self Test failed. You can try to power down computer, disconnect and reconnect hard drive from the system board. Run the diagnostics , if no error occurs then it's a cable/connector issue, if it failed with the same error, replace you hard drive,
Hope this helps!
May 30, 2010 | Dell Inspiron 1525 Laptop
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
Syntax error on Boot Up
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu
Select Safe-Mode boot
Often times drivers, or system files may be "lost" or referenced wrong, and booting into safe-mode can solve the issues, sometimes.
Check in the Device Manager for any conflicts if you are able to get into Safe-Mode.
Note any Red X or ! symbols near any devices and their names. You will have to reinstall the drivers for these devices. Consult the machines manufacturer website for downloads and support for any devices listed.
Let us know the results.
Good Luck
Apr 14, 2009 | Microsoft Windows XP Professional
Error Code 07 301
With IBM Thinkpad,it telling you that some hardware is faulty, check your keyboard to make sure nothing is stuck. Also it could also be your trackpoint. Usually, replacing the damaged part gets rid of the error! However there is a bypass key sequence that allows your to continue booting the system even though it gives you error. I'm not 100% sure of what it is but somthing like ESC at boot or F1 or maybe your need the boot to the error page then press ok, then when the system comes up again press f1 or esc then. You'll have to play around with the key sequence a bit. But to get rid of the error forever you need to replace the damaged part! Regards, Armando
Apr 28, 2007 | IBM ThinkPad 600X Notebook
Tascam 2488 Portastudio Multitrack Recorder System Logo
215 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
