Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Spin doesn't work. - Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
  • Bosch Master
  • 3,463 Answers
Hi.
First of all make sure it is draining properly, if you have not already done so, then chack the filter located at the bottom right front of washer.
It unscrews anti-clockwise.
If o/k, then you need to check the brushes in the motor for wear, if they are less than 4 or 5mm long then they need to be replaced.
If they are ok, then could be a faulty control board.
If you need any more info, then please e-mail me.
Posted on Nov 07, 2010
Machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump, or broken belt replace+lid swtich defective
It pumps, but doesn't spin
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
It spins only with the lid closed
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
Affinity does not spin
If all else operates and it is only the spin that doesn't work, replace the motor brushes
May 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
Light works, fan does not
Is it a multi speed fan and it doesn`t work on any speed?? Does the fan spin easily?? If not, the bearings have failed. If you can spin it easily, you`ll probably find that the ground wire in the coil has burned away in the connector or within the field coil windings themnselves. If it was just one of the coils, you would be missing one speed only but if it doesn`t work at all, it sounds like the grounding coil that`s failed. Ian
Aug 05, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
29 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
