Question about Sungale PD-701
Mine is a DVD9100 player, obviously older. It loads the disc and then shows no disc and will not play. I have cleaned the disc but it sounds like the disc is running and then stops. Is it worth having it serviced or just buying a new one? Valerie
  • val_morr Nov 10, 2010
    You fixed the problem, I unpluged it and then pluged it back in again. Thank you so much, I love this DVD player, you saved me the price of a new one,I am very impressed.
    Valerie Morris with thanks
  • 10,515 Answers
Have you tried to unplug and plug in the Device after few minutes, say 30 minutes?If not, try it.
It is quite a common problem with this model, you can try a clean on the lens,you can use a DVD cleaning kit which you can buy from Radio Shack or similar or you can clean manually.
To clean manually unplug from wall and leave two minutes.Remove cover identify the lens as a small round glass lens in the DVD tray assembly.Clean with the glass lens with a cotton bud or similar, use a small amount of isopropyl alcohol or do the clean dry, any other cleaning product could damage the unit.Remove any foreign objects in the unit.Reassemble and test
If no luck then you will need a new laser assembly I'm afraid.
Now, regarding Caps. Yes, it could be another Problem. When you Open the Player, you would see Caps like :-
If you see, Cylindrical Type Components, all those are Caps. There might be chance that any one of these could be Leaked / Bulged / Swelled. Make sure that there is no Cold Solder Joint and there is no other Broken Component on the Board.
If you find anything Swelled / Leaked / Bulged, you could De Solder and Re Solder the New Caps. The caps could be easily available in the Market. You could buy it Online or you could go to Radio Shack, Fry's.Make sure to Buy a Similar one. I have seen , if you buy a Low Quality Cap, it could again Swelled or Blown.Usually Bad Caps have Ammonia Kind of Odor.
The Cost of Caps would be less than $20.
I hope that the above information would be useful for you to Resolve the Problem.
Note - Sending the unit for repair would not be recommended as the cost of repair would be quite high relative to the cost of the product.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 07, 2010
  • taran_2005
    taran_2005 Nov 10, 2010
    Thanks for your response!!
    I am glad that it worked.
    Kindly accept the solution, so that i could get the credit for my time.
    Thanks and Regards
    taran_2005
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
My 360 takes a long time to load and when it finally loads it won't play games but it will play DVDs it's driving me mad I just want to play games
My xbox did same, Try cleaning the disk first, I know this is obvious but eliminate this then clean the laser , you can buy cleaner discs cheaply. if still faulty then i would change the disk drive. ( get one on ebay) . But the disk drive is keyed to the motherboard so you will need to swap the circuitboard over from your dvd player to the new one. I did this with mine with great results. You can get info on ebay how to get into your xbox .
pete
Nov 08, 2010 | Microsoft Xbox 360 Console
My Memorex won't play DVDs, it only shows "wrong disc."
No help i know, but my Liton is in the same condition. Except mine keeps saying Insert disc...
Have you tried using a cleaning disc in case the laser is dirty?
It didn't cure mine, but you never know...
Aug 15, 2009 | Memorex MVD2040 DVD Player
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Sungale PD-701 Logo
Top Sungale Televison & Video Experts
Henry  Thomas
Henry Thomas
janman
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
