Question about Bowflex Revolution Home Gym
Revolution problem: Weight jumped back on main body of machineaand cable jumped off and tangled around, under and over yellow cable. Took whole side for access and thought Ihad it beat until I realized the one end of the yellow strap was twisted multiple times and can't seem to fiqure how to untwist it. Scared to go to much deeper in disassembly without knowing where I am going.
2 Suggested Answers
  • 2973 Answers
SOURCE: up until moments ago my
A twisted strap means that it's life is over. You must change it. Even if you keep putting it on the pulley it will keep coming off. To stay on the pulley it must be strong enough not to get twisted.
Posted on Jan 19, 2010
I want to add jumping rope to my workout. Should I buy a weighted jump ropes?
I got a weighted rope because I am trying to lose weight and gain strength. This type of rope needs a lot of upper body strength and it makes you lose more calories during the same workout. It comes with 1-6 pound weights.
Jan 03, 2013 | Exercise & Fitness
I just bought a sunlite lowrider headlight for my girlfriend's vintage cruiser. I can't figure out how to open it to install batteries. Any suggestions?
It looks like the trim around the bulb separates from the main body.
Is there a button that can be pressed that will release a latch?
Maybe you have to remove the screw on the side to open the body.
Dec 21, 2010 | Cycling
What causes the thread onthe under side of my machine sewn project to bunch up and become tangled?
Make sure before you close the bobbin case, that the whole piece of thread is pulled out and put towards the back of the machine, if its bunching up dont worry about it, it might just be the way the machine is. But if it is causing problems while sewing then check the bobbin thread is not tangled inside :) Hope i helped
Oct 28, 2010 | Sewing Machines
Starts up like normal but jumps up to about 3 grand on the tach then falls down to 1.5 and stays there, engine surges at this idle. Runs good on the road till u have to stop and surges(jumps a little)....
P1294 indicates a vacuum problem or a idle motor control problem. Since you already checked for vacuum leak then the iac on the side of the throttle body will need to be removed and cleaned. The best thing to do is remove the whole throttle body so it can be cleaned as well - both with carb cleaner. The idle solenoid (motor) on side of throttle body should be removed to do a through cleaning. All of the black needs to be removed from inside both before remounting to the intake. Make sure all connections and bolts are tight before starting engine.
Sep 22, 2010 | 2001 Dodge Caravan
Hi the weight plates get struck when i am doing workout when I put on 2 weight plate and when I do heavier weight it feel i like not smooth. I notice that the weight plate is little side way when I pull...
I would the entire sequence of pulleys that lead from the lat/chest press cable to the weight stack itself to see if any of the pulley are dragging or the cable is snared. Another thing I would look for is that top plate selector pole is straight . I would loosen the allen bolt 8mm put the selector pin in one lower plate holes then tighten the bolt. If that solve the problem I take the weight stack apart and inspect the bushing for burrs that may be causing the drag.
May 10, 2010 | Body Solid Body-Solid Fusion 500 Personal...
HP Pavillion DV5 laptop - broken zif connector
Well I do fixing small things like that, no need to replace the whole main board. The problem is I live in Indonesia.
Apr 11, 2010 | Computers & Internet
Healights come on when it rains
You have a back feed (ground side).You have a wire jumping around some where or rubbing somewhere.Posible under the hood,check the relay box,and under it.
May 15, 2009 | 1998 Oldsmobile Aurora
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Oct 21, 2008 | Bowflex Revolution Home Gym
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Bowflex Revolution Home Gym Logo
158 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
