Question about Samsung HP-R5072 50 in. Plasma HDTV
Tiny/Samsung PS42D8 Plasma
Have been working on the above Plasma. Sound no screen problem. I found on the main supply board that the 2 power MOSNFET's (2SK2372)were both short and the associated 5A wickman had gone open. I replaced the MOSNFET's with IRFPC50. I also needed to resolder many dry jointed components which I have presumed were the cause of the fault. Powered up the Tv and got the same problem. All the mentioned components I replaced have survived. Q. Should I replace the associated Power Correction IC - IR2109 or could the problem be the replacement MOSNFET's? Any ideas would be appreciated.
  • 4 Answers
I have the same problem with a samsung power board in a hyaundai TV. PSU Model B4K-50.
I think my 2SK2372's shorted due to the faulty orange / red capacitors between the two FETs C523 and C524 which have the markings on them P0.22K400 which I assume are 220nF 400V.
They had basically no storage capacity left in them.
I am about to order the new parts and see if this thing powers up!
These capacitors are SHINSHIN capacitors
Posted on Sep 24, 2010
I have a Samsung Plasma TV with no sound and no picture
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 21, 2016 | Samsung PN43D490A1DXZA 43 In Plasma 3d...
My Samsung Plasma TV screen doesnt always turn on. Often I have to turn it on and off several times before the picture appears on the screen.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced
Feb 09, 2016 | Samsung PN50A650 49.96 in. Plasma HDTV
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
Hi my plasma just cut off and will not come back on. I know my plasma needs oil to work, do you know where i can purchase oil from?
NO oil in a plasma set and only circuit boards can usually be purchased.
I see so many here with no sound/nopicture issues:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 16, 2012 | Samsung Televison & Video
I have a 42" legend tv with power supply board 667-ps42d8-20, all capacitors look good but i know one or more are shot. Have you ever dealt with this tv and power supply
I just inherited the same tv from my girlfriends parents. They say they heard a loud pop and the screen went black. When I turn the tv on I hear a strange noise coming from the power supply board. It sounds like it is coming from one of the yellow capacitors (sorry if there not capacitors new to tinkering). I have read that it could be the y sus board but I feel like its the power supply board. If you have found any solutions please help me out. Thanks
Sep 30, 2010 | Philips 42 in. Plasma TV
No sound
Test on the audio output amp for a tone, check on speakers, if there is a tone you have a front end fault which could be the audio processor. If ther is no sound connect from the audio output to an amplifier for an output.Then you are lucky.... Hope it works.
Jul 01, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5052
This happened to me and it was a main power supply board. I found one at partsstore and replaced it.. that was the issue for me..
Aug 16, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Maxent MX-27X2 no video,but sound
may not be the inverter but the main board bad
Dec 30, 2007 | Televison & Video
Samsung HP-R5072 50 in. Plasma HDTV Logo
542 people viewed this question
Jerry Greenberg
Jerry Greenberg
