Question about Canon PIXMA mini260 InkJet Photo Printer
Ink transfer over image
Every time I print a picture, faint black ink lines appear over the printed image in 2 distinct strips along the bottom of the photo. Is there some sort of adjustment to eliminate both the ink and strips ?
  • 25 Answers
Did you try to clean the printer head of your printer?
You can also try to uninstall your ink cartridges and wipe the black cartridge's printer head with a dry piece of a tissue paper. Hope this helps.
Posted on Dec 18, 2009
Does not print evenly. Some lines are very faint. Have done calibration and cleaned print head several times. Prints from internet and e-mails okay. But does print from Simply Accounting, tax software...
Welcome to FixYa.
Since you have already performed calibration and cleaned the printhead, kindly verify that the ink cartridges are not damaged and are completely seated in the printhead:
1. Lift the printer access door, then remove the ink cartridges from the printhead.
2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
3. Verify that the KODAK Ink Cartridges have not been refilled.
4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
6. Close the printer access door.
7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
8.Reprint the original picture or document that had the quality problem.
Hope this helps. Thanks for using FixYa.
Dec 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I would like to print some color pictures in black & white but I cant get it to do it. Any ideas
The black ink produces dark images while color ink produces multicoloered images. Once pictures that appear in color on the computers word documents are dispensed for printing, the color ink makes possible requests. It is impossible to request black charaters from colored ink on the printer.
Feb 04, 2011 | Lexmark X4580 InkJet Printer
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
Just replaced the ink and when i print something now it is very bright if i print in coulor if its black and white the black lines are vey faint not sure what to do
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  mini260 InkJet Photo Printer Logo
115 people viewed this question
old marine
old marine
