Question about Apple iPod touch
My ipod touch will not pick up my finger and my ipod is jailbroken. How do i get the touch sensor back?
  • 87 Answers
Try a hard reset by holding down the top power button with the from button at the same time for about 15-18 seconds or till it turns off. Then turn back on.
-david
Posted on Nov 07, 2010
Testimonial: "thank you very helpful"
I have a ipod touch and it won't pick up any wifi not even my one at home all it says"is can not connect" please help
Try a hard restore, if not, seems as though you have a dysfunctional iPod. If you have jailbroken your ipod, im pretty sure that is the problem
Mar 03, 2011 | Apple iPod touch
Tip
How to install vivid themes on your iPod Touch
<p>Vivid is a set of custom themes available for your iPod Touch in Cydia App Store. Vivid Themes change the look and feel of your iPod Touch device with custom backgrounds, menus and icons. Cydia is an alternative to the Application Store, found on jailbroken iPod touch devices. Download and install themes Vivid directly to your device from the Cydia app store. <br /> <p><br /> <p>1. Touch the "Cydia" icon on your jailbroken iPod Touch. <br /> <p><br /> <p>2. Select "Search" icon and type in "Vivid" in the search bar Cydia. Select "Search". <br /> <p><br /> <p>3. Select "Vivid" to the list of available applications. <br /> <p><br /> <p>4. Tap the "Install" button. <br /> <p><br /> <p>5. Tap the "Confirm" button to download and install the application on your device Vivid iPod Touch. <br /> <p><br /> <p>6. Select "Reboot Device" button. <br />
on Jul 21, 2011 | Computers & Internet
I just jailbroke my ipod touch now were do i go to download cydia on the itouch
If you have Jailbroken your Ipod touch/Iphone, the Cydia app should be available to use. If it is not available, then your Ipod touch has not been Jailbroken, and the method used to jailbreak failed.
Jan 23, 2011 | Computers & Internet
I went to use my ipod touch this morning and the touch screen just wont work. The home and hold button work but it doesn't help because it won't let me slide to unlock. I tried holding down the home and...
hELLO THERE:
Many people think that it's a pressure problem, and the fact that the iPod is not picking up the pressure you apply when you touch the screen to perform a task. However, the screen on the iPod Touch is not pressure-activated but rather, heat-activated. This means that when you touch the iPod screen, the sensors inside the Touch pick up on the heat from your finger and follow it to wherever it goes. If it can't pick up the heat, it won't be able to do much for you. Luckily, because it's the heat sensor, the problem can sometimes be very easily corrected.
Oftentimes, this problem occurs when people are outside on a very warm day and are trying to use their iPod Touch. Because the surrounding air is just as warm, or hotter, than the temperature from the tip of the finger, the sensors can't differentiate and so, they don't respond when you touch the screen. So, just move to a cooler place and you should be able to operate your iPod Touch again. Some also suggest turning your iPod off and on and waiting a few minutes before trying again to see if it will work.
Unfortunately, if those solutions don't work for you, you might be out of luck and might just have a defective screen. If this happens, the only solution sadly is to return your iPod Touch to Apple and hopefully, you're still under warranty to get a new one.
Nov 13, 2010 | Apple iPhone Smartphone
How do you unlock an ipod touch
slide ur finger across the srceen where it tells u to
Nov 29, 2009 | Apple iPod touch
I FORGOT MY PASSWORD ON MY IPOD TOUCH 16GB. IF RESTORED THRU ITUNES WILL IT ERASE THE INFO IT HAS
Yes if you havent backedup your ipod previously then you will loose all the current data including jailbroken data( if it is jailbroken)
Nov 18, 2009 | Apple iPod touch
Slider to unlock not working?
It could be a winterboard issue if it's a jailbroken touch. Do you have winterboard installed, and if so, do you have any lockscreen themes? Try disabling all lockscreen themes, or even deleting them, then doing a restore.
Sep 26, 2009 | Apple iPod touch
My ipod touch is disabled for about thirty years and i can only turn it on and off!
Two reasons this is disabled for so long.
1. You have entered the incorrect 'power on' password many, many times.
or
2. You have jailbroken (jailbreak) your iPod Touch and one of the apps you have installed has caused the problem. Possibly a malicious app.
Two ways to fix it. Either wait 4317939 minutes or restore it using iTunes.
The first link below gives details of why a non-jailbroken iPod Touch is disabled.
Second link gives instructions on how to restore your iPod Touch using iTunes.
http://support.apple.com/kb/HT1212
http://docs.info.apple.com/article.html?artnum=305744
Jul 03, 2009 | Apple iPod touch
I HAVE A JAILBROKEN IPOD TOUCH. I WAS USING CYDIA
try calling an iphone repair company such as iphone recharge. They may be able to get you through this.
Apr 15, 2009 | Apple iPhone Smartphone
My apple itouch 8gb
is your ipod jailbroken? if so it may have to do with an app called Kate (otherwise known as caterpillar) if your ipod isnt jailbroken you might want to get it rrepaired under warranty
Jul 17, 2008 | Apple iPod touch
Apple iPod touch Logo
669 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
