Question about Samsung HP-R5072 50 in. Plasma HDTV
HP-R5072C - screen flickers and has horizontal streaks. TV is about 6 years old and I had the logic board replaced about 6 months ago.
  • 179 Answers
SOURCE: Samsung 42" Plasma-SPN4235 screen problem
the panel itself has failed
Posted on Dec 01, 2007
HDTV GURU
  • 261 Answers
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I had a mass/earth cut and it does that on my screen. What I do is I plug it where the electricity is ok
Posted on Mar 03, 2008
  • 9 Answers
SOURCE: Samsung HPR4252 with red horizontal lines accross the screen
Hey the probelm i think is the buffers low or upper left side on back when cover is taken off cost about $80 each!! Then the same for the bottom ones!! Lines will show if they go bad!! If you dont want the parts inside the plasma!! I would love to have them!! Here's my email rudog3369@yahoo.com!!
Posted on May 27, 2008
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Red noise or flicker on bottom half a plasma screen
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
My screen flickers and goes out sporadically.
Bad video graphics chip on logic board. Probably made by Nvidia. Repair logic board or replace the logic board.
Feb 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Mar 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV Won't Turn On
Are you from US or Canada? I'm Panasonic authorized and allways Pana covered the warranty after 1 month from the expire date. Call Panasonic Viera service and tell them the story. I'm sure you'll get refound.
Anyway, a horizontal line doesn't mean the PDP is defective. It's one scan IC burned on the SU or SD board (depend where the line is). We allways replaced the SC bord each time SU or SD got burned. If after SD and SC replacement it still defective...yes the PDP has one scan line in short.
Call Viera and insist to get warranty. Let me know. Good luck!
Jan 30, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung 42" HCM4216W Dim Horizontal line across screen
THIS HAS NOTHING TO DO WITH CONVERGENCE or any of the stk integrated circuits.There are few capacitors close to the vertical output ic, they are usually blue or red (could be 1000uf 50volts for e.g.)That where the problem is
Nov 03, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
