Question about Craftsman Gas Mini - Tiller/Edger
How to change primer blub on craftsman mini tiller?
    President:
  • Craftsman Master
  • 1,545 Answers
I suppose this is on the 4-stroke mini tiller. There is a circular retaining washer with "tangs" on it in the bulb housing area. Clean the area well and you will see it. It is black probably. Use a very small screwdriver and reach in and pry it out in a few different spots and it will pull free and so will the bulb. Insert the new bulb and the the retaining washer making sure the tangs on it are all nice and flat. Press it back into place with the same small screwdriver being very careful not to puncture or tear the new bulb.
Posted on Nov 11, 2010
I need the primer bulb and fuel lines that have rotted out
Go to sears and pick them up,they are waiting on you.
Aug 08, 2015 | Craftsman 2-Cycle Mini Tiller
Changed the primer blub now it wont start
If the bulb needed to be replaced more than likely the fuel lines are in need of replacement. You may have damaged one as they be come brittle with age and can crack or break easily
Apr 30, 2015 | Garden
Start mini tiller without primer bulb
Not sure if you can. It is much easier if you install the right primer bulb. Those units are made to have primers to be used I believe. if there is a place for a primer it needs one.
Jul 10, 2014 | Craftsman Gas Mini - Tiller/Edger
How to change out the primer bulb if a crack in it and where would you be able to purchase one?
you should be able to get one from your local small engine rair shop, and you have to re.ove the plate on the carb. that holds it in place.
Jun 22, 2014 | Craftsman 31cc 2-Cycle Mini Tiller
Why will the plastic primer area will not fill up?
One reason that the primer bulb will not will with fuel, besides having no fuel in the tank, can be that the two fuel lines have been reversed. If you pulled the fuel lines off for some reason then switch their positions and see if that makes a difference when you push the bulb. You should see fuel moving back into the fuel tank.
Jun 22, 2014 | Craftsman 2-Cycle Mini Tiller
Can I replace just the primer bulb
yes useing a thin small screwdriver slide it down the side and work the spring slowly out revers this to put a new one in
Feb 14, 2013 | Mtd Craftsman 4Cycle Mini Tiller
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Gas Mini - Tiller/Edger Logo
230 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
