Question about Mr. Heater MH175KT Open Flame Utility
My heater has no fuel pressure - Mr. Heater MH175KT Open Flame Utility
  • Mr. Heater Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Nov 07, 2010
Starts then shuts off
REAL FACT is: If all individual components of the heater are at 100% but the air pump pressure is not on it's mark, then the heater WILL NOT continue to run!
Air Pump Pressure is directly related to fuel delivery. Read that statement again! It is the most important line of text on this website.
If the pump pressure is incorrect, then, the fuel delivery will be incorrect. As a result, the heater will not run to specs.
Instructions for setting the air pump pressure:
Air pump pressure is the pulse of the heater. Pump pressures range from 3 psi to 6 psi depending on heater BTU size (see chart below). A loss of ONLY 1 psi translates to a 30% to 17% loss of FUEL FLOW (starvation). You must know the specified required pressure and set the pressure accordingly.
Heaters with Hot Surface Ignitor technology are extremely critical to pump pressure. If the pressure is off by 1/2 psi, the heater may run for 5 seconds, then shut down because of IGNITION FAILURE. The only way to correct this problem is to set the pump pressure to DESA's recommended pressure specification.
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Feb 17, 2015 | Reddy R60A Utility Heater
Starts then shuts down
or
Mar 02, 2014 | Reddy Heater-170,000 BTU Kerosene Deluxe
Runs when started but won't stay running.
or
Feb 13, 2014 | Reddy HEATER R70DT 70,000-BTU PORTABLE...
Reddy heater 170T will not ignite fuel
what is your air pressure, very important. Air pressure should be between 4 to 6 pounds.
Apr 04, 2013 | Reddy Heater-170,000 BTU Kerosene Deluxe
Porta heat 55 model 50137 does not work, fuel problems
or
Jan 21, 2013 | Reddy Heating & Cooling
My kerosene torpedo heater turns on but then it dies after five seconds
or
Jan 08, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heater glow plug ignites and blower comes on but no fuel ignition.After a few seconds the motor cuts off and glow plug goes out.
You should check for fuel flow. Remove the top of the heater. Watch out for the fan and turn the heater on. Look for fuel spraying from the nozzle with a flashlight. If there isn't any, clean the fuel nozzle and check your fuel filter. If this doesn't get your fuel flowing, check the air pressure going to the fuel nozzle. You will need to connect a pressure guage one of the ports on the airfilter cover. The plug with a small hole in it is for adjusting the air pressure. Remove the other plug and install an air pressure guage (0-15 psi). The air pressure you need should be listed on the label on the heater. If you can't get that pressure, check the air filter. Let me know what you find if this doesn't get you going and I will give you some other things to check.
Jan 01, 2011 | Reddy Heating & Cooling
Bought a new ignitor, but it doesn't ignite
Is fuel getting to the nozzle? With the top of the heater removed, use a flashlight to look for fuel spraying from the nozzle. If it isn't, check the fuel filter. Have you check you air pressure going to the fuel nozzle? The required pressure should be listed on the data plate of the heater. If you can't get the air pressure right, your air filter could be the problem. Let me know what you find if this doesn't fix it.
Dec 27, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
100,000 btu therm controled heater
What did you set the air pump pressure at? This is critical on heaters with Hot Surface Technology. Setting the pump pressure is always the FIRST place to start troubleshooting on these heaters.
Here are some things that can prevent ignition even though there is fuel & glow:
  1. wrong air pump pressure
  2. the nozzle is restricted & distorted not allowing fuel to contact the glowing ignitor
  3. the nozzle is worn. It should produce a cone of fog, not a spray.
  4. there is water in the tank below the fuel.
Oct 23, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Mr. Heater MH175KT Open Flame Utility Logo
258 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Bill Long
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
