Question about Samsung Galaxy S GTI9000 Smartphone
When the device is connected to the PC it shows MTP device error and PC is not detecting the device at all..
I can't connect my galaxy s to my samsung kies. It tries to connect and screen flip between main menu and usb connect picture all the time.
Thnaks
Posted on Dec 18, 2010
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
Tip
My Computer won't recognize my MP3 player...
For Windows XP users: verify the following operating system requirements are met.- Windows XP SP2 or higher- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.- Download the hotfix from http://support.microsoft.com/kb/939211.- Run the hotfix.
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
Next:-- Refresh the drivers. Connect the MP3 player to the PC. The screen on your player should turn on, show 'Connected' and indicate the battery is charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.NOTE: - If there is nothing showing on the screen and the player does show up as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed.
Next - Check under Device Manager1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Most MP3 Players can connect to your computer in MSC or MTP mode. There are exceptions which only use MTP mode. MTP mode is the recommended and default method for some MP3 players. Some players will show up on Device Manager's right pane as:1. USB Mass Storage device (if the player is set to MSC)2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, refresh the drivers. To refresh the drivers1. Right-click the error mark, select Uninstall.2. On the top menu, click Action then select Scan for hardware changes.
Next: - Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player.
The USB Mode setting can be enabled on some players after updating to the latest firmware. If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the firmware.
on May 31, 2010 | Audio Players & Recorders
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
Refresh the drivers
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
STEP 2 - Check under Device Manager
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
STEP 3 - Refresh the drivers
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
4. Power issue.
- Run the hotfix.
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Connect the player to your computer.
- If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
<<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager
1. Right-click My Computer, and select -- > Manage.
*** See This Tip Posted here ****
Solve your MP3 Player Connection Problem.
Refresh the drivers
>>>> BUT TRY THIS <<<<<<<
Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
MTP DEVICE DETECTION
What I would tell you go to the manufactures website and download a driver for your player and this should fix your computer not reading it right.
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Samsung Galaxy S GTI9000 Smartphone Logo
759 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
