Question about HP PSC 1610 All-In-One InkJet Printer
How do I reset the printer to the english language panel display
  • 857 Answers
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Posted on Nov 07, 2010
How change language for printer brother mfc-j 5910dw to english
To help you change the display language for MFC-J5910DW Brother printer and copier, please follow the steps given below:
- Press 'MENU' on the printer screen.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Initial Setup.
- Press 'INITIAL SETUP'.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Local Language.
- Press 'LOCAL LANGUAGE'.
- Press 'ENGLISH'.
- Press the 'STOP/EXIT' key.
If issue persists, please contact Brother Printer Support Center from the link given below:
http://www.brother-usa.com/askus/default.aspx?PGID=5&R3ModelID=MFCJ5910DW
GuruAid.com
May 30, 2016 | Brother Office Equipment & Supplies
Need to change language to English
From the printer control panel display, touch and slide your finger across the screen and then touch Setup. Then open Tools. Look around the tools menu to see if there is any language change. If there isn`t any just reset the printer to factory defaults.Use the link below and page 39
http://ecx.images-amazon.com/images/I/D1QEFw7XJ6S.pdf
Dec 28, 2015 | HP OfficeJet Office Equipment & Supplies
Want to return printer language to english
1- Press and hold SELECT while simultaneously pushing the power switch ON.
Hold SELECT until SELECT LANGUAGE appears, then release SELECT.
2- LANGUAGE=ENGLISH will display.(this may be in your current language and unreadable, just follow along to the next step)
3- Use the VALUE - and VALUE + keys to select the desired language. (just keep pressing until you see the words "ENGLISH")
4- Press SELECT to save your selection.
The control panel display will indicate the printer is ready to use.
Jan 01, 2011 | HP LaserJet 8100 Printer
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
Change the language on hp laserjet 4000 to english
For the LJ4000 to change the control panel language:
Turn off the printer.
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
Nov 30, 2010 | HP LaserJet 4000 Printer
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
LANGUAGE
Follow these steps to resolve the issue.
  1. Unplug the power cord from the back of the printer.
  2. Press and hold the # and 6 buttons simultaneously on the control panel, and then reconnect the power cord.
  3. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  4. If the product automatically turns off, turn it on. CAUTION: Do not perform a NVM reset before the initialization process is completed on the product.
  5. Allow the product to fully start up, and then select the correct language code and country/region when prompted.
Oct 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Panel shows different language
Follow the following steps:
  1. Turn off the printer.
  2. Press and hold down the right VALUE button.
  3. While holding down the right VALUE button, press and release the POWER button.
  4. When INITIALIZING appears in the LCD, release the right VALUE button.
  5. The message VALUE AND SELECT KEYS TO CHOOSE LANGUAGE is displayed in the LCD and the currently selected language is displayed as =ENGLISH .
  6. Press the VALUE button until the desired language is displayed.
  7. Press the SELECT button and the desired language is now selected and displayed in the LCD and the printer returns to the READY state.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Change language
1. Unplug the power cord from the back of the product.
2. Press and hold the Cancel and Color Copy buttons simultaneously on the control panel.(My color button was the green button)
3. While still pressing the buttons, reconnect the power cord to the back of the product.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
5. If the product automatically turns off, turn it on.
6. When prompted, select the correct language and country/region, and then press the OK button. Press the OK button again to confirm the selection.
NOTE: Some products might have a promotional sticker on the control panel display. Make sure that any stickers are removed from the control panel display before troubleshooting this issue.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
These directions were copied from the following url:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368025&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search
Solution
Jan 06, 2008 | Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
464 people viewed this question
Seeker5211
Seeker5211
