Maytag Epic Z washer F1 error
I cancelled a load this morning and the washer acted like it was draining... the door unlocked and i found some water still in the bottom. I selected the spin only as the manual indicated and was rewarded with and F-01 error. Any ideas how to clear it? i have unplugged, selected other modes and cancelled multiple times...please help
  • 1 more comment
  • jonied Jun 28, 2008
    I cannot start the washer at all.... whenever I set any cycle press start, the washer responds with an F 1 error
  • Anonymous Jul 01, 2008
    I must had the epic washer two days. The wash stopped and I wanted to spin it some more as I had a load with several towels in it. It never started again. F-1 is all I got. I called the 800 number and the person told me to turn off the power and wait and turn on again etc., as it also stated in the manual. He finally said if this did not work (which I believe is a common problem) to call a tech. Of course I would have to pay to have it fixed which in itself is not pleasing since I just got the machine and payed 89 dollars for the tech to tell me my other one (Neptune of eleven years and my second Maytag in twenty years) would be 425 to fix. Thus the decision to get another Magtag as the previous machines did right by this family.
  • Anonymous Jan 18, 2009
    I got the same problem...this means I have to call the tech. Darn it, we just got this washer machine.
The F-01 problem is a computer board error. If you have warranty, call them up and they'll replace them for free. If not, I think it's going to be pretty expensive...
Posted on Jul 13, 2008
No I have a code 5d what does that mean on A Epic Z front washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 03, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F71
Select POWER/CANCEL twice to cancel the cycle.
Select DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START/PAUSE.
If the problem remains, schedule service.*
Jan 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Re-select the cycle and press Start/Pause.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
How to I release the "Control Lock"?
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
good luck
thanks
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
When we turn on our front load washing machine it trys to drain. it does not start filling with water it acts like it might be stuck on the drain cycle
Seems it detects water from previous run. Is common phenomenon on bad drain hookups or faulty vacuumswitch. Rarely, the timer is damaged.
Apr 09, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
1,317 people viewed this question
Top Washing Machines Experts
