Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Front Display is saying DR-2 and will not let me use remote to control anything...only thing I can do is shut power off with front panel..I have unplug from outlet and let set for 30mins and plugged back in and it will not reset......this all started because of having to change the time for daylight savings...we have sat not cable and so I had to do it manually....I must have done something wrong to cause this....I also pulled batteries from remote thinking I needed to reset remote....but to no avail....thanks for any help. rd-xs35su is the model of recorder
I received an attachement from the Toshiba Repair folks several months ago, when we had the same problem. To resolve it, do the following:
While pressing the Easy Navi button on the remote, press 2. The remote control mode will be set to DR 2, which is what the recorder is telling you it is set to.
We encountered this problem for the first time, for no apparent reason. It happened again today, after the operator dropped the remote. This fix worked both times.
Posted on Dec 27, 2010
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
My tv says locked on the screen. i dont know what to do with the rmote. it will turn on and the channels will go up and down but says locked on the screen
Hello
As you have its remote things are easy. If you have forgotten the passoword do the following.
make sure the TV is off. Simoultaneously press and HOLD VOL. Enter a next password next time you access parential control menu.
If this does not help do the following
[1] Hold dow n [0] on the remote control and volume [2] Hod down Menu button on the front panel of the TV and 'TV' button on the remote control at the same time for at least 5 seconds.
[3] Hold down "Go Back" on the remote control hanset and "Menu" on the front of the TV at the same time for at least 5 seconds.
[4] Hold down "Eject" on the front of the TV and the "Menu" button on the remote control hanset at the same time at least 5 seconds.
Depending on the model one amoung these steps will unlock RCA tv. OK.
Nov 13, 2010 | RCA 32F531T 32" TV
My dvr had a timing issue and said to check the IB? or BI? so I went to the setup and seen the IB menue,.. it was on DR-1 and I clicked on DR-2 and now I can't do anything using the reomote. It only works...
Go to the menu button on your dvr look closely it wil tell you what button to use. Once there go back to setup and undo what you did. After this go into the menu where it says restore to factory settings and restore it to the factory settings. This will resolve your problem.
Aug 18, 2010 | Toshiba RD-XS52 DVD Recorder
Says "dr", will not start
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Front panel only lights up wen turnd on or adjusting ...after it turn s off
Need to press the fl dimmer button on the front panel it controls the display.
Jan 29, 2010 | Pioneer VSX-D409
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Sampo DVE-611 apparently powers up from front panel switch (w/red light) LCD display, etc. No other buttons work, incl. eject. Remote completely unresponsive. Unit shuts down about 10 sec. later. Anyone...
After several power ups, the front panel buttons eventually "woke up". Replaced remote, and everything's working fine. Not sure why the front panel was temporarily unresponsive.
Jul 16, 2008 | Sampo Televison & Video
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
391 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
