Question about Dremel Garden
How do I change the drill tips on the Dremel 370 6 model? Can't find the instructions. Thanks
    Brigadier General:
  • 4,088 Answers
There should be a shaft lock button near the tip end of the tool and you need a small spanner wrench (included with the tool) that inserts into the collet sleeve hole and is turned CCW (looking at the tool end) to loosen the collet itself. Tap on the tool end lightly to help loosen the bit. Hope this helps!
Posted on Nov 07, 2010
Is there a specific tool recommended to loosen the set screw so I can change the tip? It doesn't mention anything in the directions
Engraver Kit / Model: 290-01 - Dremel.com
www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=290-01
DremelFeaturing a replaceable carbide point, Dremel's engraver kit lets you work on metal, ... http://mdm.boschwebservices.com/files/Dremel Engraving Tool 290 ...
Amazon.com: Dremel 290-05 120-Volt Industrial Engraver ...
www.amazon.com/Dremel-290...Engraver/.../B000VZ...
Amazon.com, Inc.
Rating: 4.2 - ‎62 reviews
Dremel 689-01 11-Piece Rotary Tool Carving and Engraving Kit .... tips and came from a different source ie there is no Dremel 290-05 tool. ... On the very first tool, afterengraving the serial number, the diamond tip began to loosen and slip out. ... When I returned to the engraver to tighten the set screw the tool fit perfectly, ...
Home Depot Dremel 120-Volt Corded Electric Engraver ...
reviews.homedepot.com/.../dremel-120...engraver...tool.../questions.htm
Afterwards you can remove the paper and glue with a simple adhesive remover or alcohol. ... I use the Dremel Electric Engraver Tool to engrave manufacturers name and model .... hardware store and they should be able to supply a new set screw for you. .... The 290-01 Engraver is for engraving applications only and is not ...
FAQ - Customer Service - Dremel
www.dremeleurope.com > Home > Customer Service
Dremel Europe
Dec 16, 2015 | Dremel 290 - 01 Engraver
Dremel User Manual
i would advise you to contact the company making them and ask if they can send you the users manuals, in my experience they will send it too you.
Nov 09, 2013 | Drills
I want to use my USA Dremel Stylus in Europe. I already ruined a docking station, using my 110-220 transformer. I now have a new dock but what type of transformer should I get? Dremel says it should put...
I presume you want to use a transformer to convert the Europe voltage to USA voltage ( 220 or 240 to 110 )
Why not purchase a 240 volt docking station ?
Send me the 10 digit number on your Dremel (usually starts with F ) and I can help you.
Oct 09, 2013 | Dremel Drills
Where can you find a Dremel model 780 battery
I'm not sure why but, the Dremel 9.6 volt battery is only available through a Robert Bosch retailer or authorized service center. Their homepage is at www.boschtools.com/Pages/default.aspx where you can search for the nearest service center under the 'Service' tab.
Jul 12, 2012 | Dremel Drills
When I turn on my 7.2v minimite the tip spins, but stops when I just hold it with my fingers. I changed the sandpaper on the tip and think maybe I did something wrong, any idea how to fix it?
Hi. Is this a small rotary tool, like a Dremel? If so, I'm afraid it is probably just a weak tool with no torque. Buy a Dremel tool.
Sep 14, 2011 | Drills
I bought a dremel 4000 on ebay and it didn't have a manual with it - I need basic instructions to use the drill bits I purchased that go with it. Is there an adaptor that I need to use them?
Your drill bits side, should have a twisting hand tightening head into which you insert the bits, and have fun. If this is missing, you can either buy it, at dremel stores, or get a nut of the same thread and get the job done.
Sep 07, 2010 | Dremel Drills
I can't find instructions for dremel versatip to change the heads how do you do this
The pdf manual is here: http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00554v-1.pdf
BUT it doesn't explain how to change the bits. If I remember correctly there is a grub screw near the tip that you loosen with a small flat blade screwdriver to change the tips. If your model is different then perhaps posting a picture would make it easier to give a better description.
Apr 05, 2010 | Dremel 1550:30 Versatip Tool Kit
Did not receive manual in my box, for Dremel Driver 7.2v model # 1120-01, how could I get a copy. thanks mark
go to Dremel.com and they can get you one if they are not available online at that site.
Jan 20, 2010 | Dremel Drills
Hi, My drill(Dremel) just doesn't turn on. The sliding switch moves, but nothing happens. The switch moves losley too. It seems dead! I wasn't present when it broke. I do not know any details on what...
With the machine unplugged, check the motor brushes. They may be worn.
I have not had success doing any other repairs to the motor part of a Dremel. I do know they have a service center. Go here for more info:
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Thanks for your question at FixYa.com
Jan 15, 2010 | Drills
Dremel Scrollstation 1800 motor fault
There seems be problems with the electrical systems of the Dremel 1800 scroll stations (had same problem)
Speedcontroller burns out and DC motor gets hit by Main AC voltage.
Earth leakige due to low resistance between DC motor Rotor and earth (flowing current to earth)
Measure rotor copper connections to earth to check for low resistance, should be very high.
Biggest problem is that the main metal body under full main voltage comes and this is a dangerous situation!!!!!!!
All to fix is to repalce (both) fauly parts,
Motor Controller and DC motor
Hope this helps
May 19, 2009 | Dremel 1800-01 Scroll Station 18" Variable...
Garden Logo
283 people viewed this question
Top Dremel Garden Experts
Dennis Key
Dennis Key
john h
Are you a Dremel Garden Expert? Answer questions, earn points and help others
