Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have a Poulan 733-864 14.5 Briggs motor. I cannot get it to start. Battery tested fine but there isn't enough oomph to turn the motor. The starter has a rusty nut and post where the cable attaches. Could this be the problem? Do I have to replace the starter?
    President:
  • 3,074 Answers
I would start my car/vehicle and hook up a pair of jumper cables and jump the mower, more then likely the battery is out, Wal-mart sells them for around $30. Remember to hook the cables to the mower fist, making sure you will be able to sit on the seat without causing the cables to short out, then hook them to the vehicle, depending how far gone the battery is you may or may not need to start the vehicle. Good Luck Tim
Posted on Nov 07, 2010
Engine won't crank. battery charged up. alarm sounds go off,
The battery is charged up, but still remains suspect, because a failing battery cannot hold enough oomph to crank the motor, even after charging. So -
- failing battery, especially if 3 yrs old or more
- worn starter solenoid contacts
- failed starter solenoid coil
- dead spot in starter motor windings
- bad contact at either end of battery ground strap
There is a crude test. Turn on the headlights and try to crank the motor. If the lights dim down a lot, it is the battery at fault.
Jun 14, 2014 | 1995 Toyota Camry
Sarter will not turn engine over
Two things cause this...a bad starter or weak battery...not sufficient Amps will not allow enough power to the starter to spin it fast enough to start the engine....a bad starter simply cannot use the power supplied it to turn the engine properly. Have some one do a load test on the battery..tests the battery simulating starting the engine. If ok it is the starter if not replace the battery..good luck.
Apr 09, 2014 | Briggs & Stratton Starter Briggs Stratton...
Have Poulan riding mower with 135 cc motor. Battery is full charged but the engine is not turning over. starter is not turning at all
Check the safety switches, especially the blade safety switch, people forget that one. Blades must be disengaged to start the engine.
Aug 14, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. ...
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Jul 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engine won't turn over
Is the engine flooding the cylinder with gas and hydro locking it? Try pulling the spark plug and seeing if the engine can be turned over and keep note if any gas comes out.
May 07, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine will not crank with every try.
Still sounds like a valve adjustment problem and as for relying on a Sears serviceman.....well. lol I just did a valve readjust on basically the same engine with identical symtoms and it starts fine now. As for the 10w-30, Briggs recommends 30w in the warmer climates.
May 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
362 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
