Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Hello, after about one year of well working this mobo starded giving problems. Now, when i turn on my PC the green power light on the mobo (sb pwr) is on as well as the green led on the case. The CPU (ATHLON 64 X2) and PSU (BITROM 500W) fans work, but the screen is black, no beeps, no POST, no BOOT, the mouse works but the keyboard not. I cleared the CMOS by the jumper (CLRTC) and tried to reset also the KBPWR jumper. I tested the system without the VGA (ATI 1950 PRO 256 MB), without the sound card (creative), without RAM (TWINMOS PC2 5300 CL5 512 MB X 2) but nothing. I'd like to reset the BIOS (in the past I solved in this way the same issue on another mobo) but i don't know if i did it by clearing the CMOS or not and what's the right way to do it. Can you help me?
  • ASUS Master
  • 5,660 Answers
1) You can just use C.P.R. (CPU Parameter Recall) to reset BIOS back to the factory default settings, as well as the CLRTC jumper. (Clear Real Time Clock. Another way of stating clear CMOS)
You may had luck in using this method on another mobo, but IMHO it isn't the problem/solution for this puppy.
I think you have a bad Power Supply with a weak voltage power rail.
Enough power to light LED lights, and spin fans, but not enough to turn the Processor on.
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can consume 51 to 125 Watts of power. (Maximum) Depends on what Processor it is.
The Asus M2N-E SLI mobo has an AM2 processor socket, and can use AMD processors that consume a lot of wattage.
No Processor operating, No computer.
No computer operating, there is No Video Signal to the monitor.
(No Signal)
Do you have a KNOWN to be good, compatible Power Supply, to use for a test unit? Perhaps there is an unused computer. Maybe someone has upgraded to a better computer, and there is an unused one.
Posted on Nov 07, 2010
Green light is on pwr suppy. +12 and +5 volts a little low. Power_On volts goes from +4.8 to 0 at startup on 24 pin pwr connector.computer beeps 3 sec.off and on till turned off. HP Pavilion 7955
Pavilion 7955 , 1997 year.a very old Pentium 4 , Desktop the PSU is bad.
its only worth for the trash, any P4 puter, it's junk .
4.75vdc is low as is allowed.
did you jumper test the PSU first.
the MOBO and thE PSU can both turn it off.
so can shorted modules, remove all not needed things first.
dvd , and all hdd .
all usb.
all memory but 1 stick in bank 0
even remove video card. if it has one, must now turn on.
unplug the 24pin, and place the jumper seen here
the PSU must run, if not the PSU IS TOAST.
if it does run we top the mobo unloading, of all things that can short out..
http://www.pcdied.com/power.html#Jumper
Oct 21, 2017 | HP Computers & Internet
Pwr flashing on mother board after turning it off
unplug the line cord
push the power button for 15seconds,
see the caps discharge see that green LED go dead>?
the ASUS, (no model stated) the lamp on the mobo is standby power,warning LED.
now work in the mobo, dead cold doing this the correct way.
per above.
with power 100% dead and the green light out.
that light means leave me alone, standby power is active
if you hot switch devices now damage can happen very easy.
learn the 1 rule in electronics, never hot swap parts
unless like my server the SAS drives hot swap, oK?
but most things DO NOT hot swap, that is rule if you need learn why, I can teach you.
The surge current during a hot swap can get near infinity.
what is the rise on a large cap shorted, google that.
ask Your EE teacher or bud that.
I can demo that, and blown the end of a screw driver totally gone.
goggle fitted to eyes, its ugly.
once learned this , you now work is such a way as to
do not harm first..
Mar 07, 2018 | ASUS Computers & Internet
Sb pwr light keeps on / one beep and the PC turns off
Check that keyboard is plugged into correct port.
Can you Enter CMOS setup ? Try replacing battery on main board.
Oct 21, 2013 | Intel Computers & Internet
Dc 5000 sff. wont power up. green light on motherbd flashes. if power on button is pushed, the front green led blinks too. I have replaced the pwr supply w/no change.
make sure both the 4 pin and 20 pin connectors are firmly installed. if the mobo light flashes how many times does it flash, do you hear any beeps?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 10, 2012 | HP Compaq dc5000 PC Desktop
System wont turn on and there is a solid green light at the top of the mother board of my gateway 310 pc replaced batt on motherboard and it still wont turn on.
hello, this be caused by several things , i am assuming your are okay with opening up a PC since you have already changed the onboard battery.
here are few things you can try to further troubleshoot:
1: though the ligh on motherboard is on, power supply can still be faulty, so lets test that with a paper clip trick,
follow this link there are pictures and very clear instructions: http://www.ehow.com/how_4732521_test-desktop-power-supply.html
if power supply is bad, well then you know what to do... change it.
if the power supply is good:
2: remove all the RAM (memory) chips from motherboard and plug the power cable back in and observe the response (you may or maynot hear THREE beeps) now plug in memory chip and try powering up and try with one chip at a time...if PC boots up with any of the chips in it you knkow you have a faulty memory.
if that didn't work:
3: with everthing put back together try disconnecting just the hard drive and power it to see if you see BIOS screen.
if not:
4: many time this worked for me with Gateway PCs, reseating CPU in its slot but only do it you feel confident doing it because you can end up with a GIANT door stop if any of the pins on the CPU are/is damaged.
you would need some thermal-paste to go back on between CPU and heatsink.
if that didn't work..i think you are up to buying new PC.
let me know if you need more help or not clear about anything...
good luck
Amar Sondhi
Dec 04, 2009 | Gateway 310S (2900621) PC Desktop
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Atx power swtich replacement
Either way will work! No worries, it is just a switch. Just think about it. A jumper wire would work as well, right?
Oct 20, 2008 | ASUS Terminator PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
136 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
