Question about Briggs & Stratton Garden
Engine runs rough, burns tons of oil, and keps shutting down
    President:
  • Briggs & Str... Master
  • 1,388 Answers
Could be too much oil. Check oil livel and make sure that the oil is not too thin (gasoline in oil). Install new spark plug, add premium fuel in tank and start engine without the air filter (air filter could be dirty or soaked in oil). Run for a while to see if condition improves (no or less smoking). Replace air filter while the engine is running to see if it makes a difference in performance. If installing air filter had no effect, and engine continues to smoke most likely valve guides or rings are faulty. Hopefully it will clear up. Good luck
Posted on Nov 07, 2010
I have a 2005 9.3 arc and theirs a ticking noise coming from engine it idles rough and it burns oil what could it be
Ticking may be valve lifter collapsed. Rough idle and oil burning could be burnt valve and poor maintenece. Run compression test to determine condition of rings and valves.
Feb 23, 2015 | Cars & Trucks
Troy bilt troubleshooting
might be low oil sensor trying to shut the engine down, on a hillside the oil would go to one side and the sensor is thing the unit is low on oil.
Jul 28, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
Oil level rise on dipstick
Black smoke is either a rich running carburetor or oil is being burned. Most carburetors are adjustable. Try adjusting any screws for best run. Oil burning and level could be a plugged crank case breather (cleanable), bad rings or valve. Good luck with this one.
Dec 14, 2013 | Garden
Oil light came on runs really rough and then shuts down. so far i replaced fuel pump, mass air flow sensor, oil pressure sensor and oil level sensor. nothing yet. no check engine light either.
Don't run the engine with the oil light on. No oil pressure means no oil circulation, and damage will result. Have a shop check the oil pressure with a gauge that plugs into the oil pressure sensor port. If no pressure, check if you need a new oil pump.
Aug 03, 2013 | Cars & Trucks
92 dodge dakota stalling,running rough,loss of power
Did you replace the fuel filter when you replaced the pump ?
Was it running rough before the pump was replaced.
Did you replace the cap and rotor too ?
"Sucking a ton of air" could be a vac leak, or the sound of the throttle open when the engine is bogging down.
Is the check engine light on when it is running ?
Jul 05, 2012 | Dodge Cars & Trucks
My service engine light is on and the engine is running rough . What doni do ?
Shut down engine immediately before more damage is done. The engine oil and the oil pressure condition must be checked.
The timing belt condition or if the period has elapsed for changing the timing belt must be checked.
Jun 14, 2011 | 2003 Nissan Altima
What will over filling a 1995 accord with oil do
It will cause the oil pump to burn out making the oil flow through the engine not possible and eventually blow the motor from over pressure.
Oct 27, 2009 | 1995 Honda Accord
Endeavor burns a ton of oil...
These engines have been known for faulty cam seals (eg. Montero, Montero Sport (Nativa), Endeavor). You might not see oil on the ground because it gets burned up by the exhaust. Check that first.
Oct 09, 2009 | 2005 Mitsubishi Endeavor
Runs rough, lags, and will backfire if I push it
This is probably one of four things or a combo thereof...dirty fuel injectors, cracked distributor tower/burned points (if it's not electronic ignition), burned valves or air/gas flow sensor if it's computer controlled (the chip is likely bad).
Jul 21, 2009 | 1997 Dodge Ram 1500 Club Cab
Garden Logo
307 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
