Question about Samsung Televison & Video
I have a Samsung 32", model code LNR328WX/XAA,
  • 308 Answers
SOURCE: Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Posted on Jan 01, 2007
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Posted on Feb 20, 2009
  • 22 Answers
SOURCE: LG RT-42PX10
everyone's lucky day!  follow this link closely!  it will work!  it worked for me on my gateway, which has LG boards.  trust me.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
Samsung flat-screen TV model LNR328WX/XAA has no picture. Sound is okay. I suspect the power supply board has failed, and would to confirm that, before I order a replacement board.
I would definitely check on the SOURCE button on your remote control, set accordingly first. EXAMPLE#1: HDMI (1) / HDMI (2) or (3) or (4) / Component inputs, EXAMPLE: GAMES LIKE A X-BOX / Check the Regular TV input. Good Luck.
Jul 05, 2017 | Samsung Televison & Video
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
Gentlemen; We purchased a 32 inch hygh def TV app 3 years ago. We had an issue with a burned out 32 inch model and had a certified repair tech come up to our home and had the main board replaced in I...
Please note that we are not affiliated with any company. We are a bunch of independent consultants with hands on experience at fixing stuff. However if you can get me the make and model of the tv along with country of residence I can get you the contact info of the customer service department so that you can get it replaced.
Oct 31, 2010 | Televison & Video
Greyish marks on Samsung 32'' LCD TV
it should be covered, can call 1-800-samsung for nearest authorized service center or go to samsung.com
Dec 31, 2009 | Televison & Video
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
227 people viewed this question
Jerry Greenberg
Jerry Greenberg
