Question about Timex Watches
I dropped my watch and the back popped off. How do i put it back on > there are no screws and it doesn't look threaded. When i try to popped it back on, the other side pops up. Suggestions ?
  • 7 Answers
SOURCE: The back cover for my watch popped off when I
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
  • 5 Answers
SOURCE: I have a round ladies gucci watch on which the
That Gucci watch requires a special tool that looks like a crochet hook. I highly recommend you take it to a jewellery store that carries Gucci to have it changed.
Posted on Dec 20, 2009
escapement
  • 2334 Answers
SOURCE: how do you put the back, back onto this fs1? The
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
Posted on Mar 04, 2010
cmcduncand
  • 714 Answers
SOURCE: back popped off using tip of knife but cannot get
There is a press for putting these back on.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on Mar 11, 2010
ynogami21
  • 670 Answers
SOURCE: NEED TO CHANGE THE BATTERY
If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit. if it doesn't then look if there is a hinge where you can insert a small flat screw driver head or a small flat stick to pop the back of the watch.
Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
Posted on Jun 21, 2011
Dropped watch on floor and doesn,t work.
Simmon, Try to take the back off watch, and remove and reinstall battery. The watch battery some times looses contact when dropped or hit sharply. I have had to do this on different watches that have been dropped.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 12, 2016 | Watches
Help removing the back off my Sili Orange Uni Ice Watch PLEASE
Hello Linda McMahon,
The six slots are indeed the way it is done...
The correct tool is called a jaxa...
(don't go TO cheap... they won't hold their ADJUSTMENTS
(back removal: yes cc = loose))..
You can get a good look on both eBay & Amazon (I'll put up pix with URL (links) for your viewing pleasure.
Using AYTHING but a GOOD quality three jaw wrench will guarantee the metal will get damaged... each & every time it is accessed (making future attempts that more difficult).
The key to success with the jaxa wrench is:
- good fit (primary adjustment),
- right bits &
- lots of firm PATIENCE.
First time might take some real force... they seem to employ the Samsonite Gorilla to do the first closure... The notion that these watches can be used for any SCUBA-DIVING... is actually quite fun... but for practical purposes you should treat ALL "water PROOF" watches as water "resistant"... (MY opinion).
Meaning SNUG it good enough when closing.
If you want to get wild... take one of those needle (synthetic clock) oilers... put a dab (not a drop) on some clean paper. Get a clean tooth-pick.. moisten its end and touch around those back threads about where those six slots (you mentioned) show.
If you see any moisture... pick it off with a clean cloth.
That will help gently getting the back to ***** together without messing up the "O" ring seal.
Three tips:
Always clean the watch thoroughly before opening
(old tooth-brush works good)... wipe down with soft clean cloth.
You will also need a jewelers loupe... While BIG magnification numbers sound good initially... working under more than 5x or 10x... will prove to be pretty awkward
Finally... work over a linen napkin... that can catch small screws, batteries or clips that try to fly away when you are working...
OKAY four... a vacuum with an old tee shirt
used as a primary filter CAN (AND HAS) FOUND screws I dropped when I was intellectually challenged enough to work above a carpet...
Okay FIVE... A flash-light shining across the floor will make the tinniest part cast a reasonably good shadow... (really helps).
If you think you can actually handle the iddy biddy things without
popping a couple away... you are sillier than I am... Comment me back... for any other help... (except LOST PARTS).
Good Luck... and Happy HUNTING
Timewheel TWJAXA2 Back Opener Wrench for Large Waterproof Watch Cases With...
Waterproof Watch Case Opener in Wooden Box
watch back case opener jaxa wrench
Apr 10, 2016 | Ice Watches
How to remove the back on a Casio #2532 Watch
many watches the back that screws on and off . and prying just damages the threads so they never seal properly again .
Jun 30, 2015 | Casio Watches
I bought a watch and we can't get it to work. We think the battery needs to be changed.
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
May 24, 2011 | Cars & Co Disney Pixar Cars Mcqueen Analog...
Back popped off using tip of knife but cannot get it to pop back on! I don't see any groves to line up or any threads. It is a timex indigo
RECOMENDATION:
GOTO
r/ David
Mar 11, 2010 | Watches
Screw down crown wont lock
There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
Rate me, plz.
Jan 06, 2010 | Watches
Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Dec 05, 2009 | Watches
How to open the back of a wrist watch to change the battery. i have two disney watches both have red m on the litle dial you use to set the time the model numbers on back of the watches are: mu1240 mu1108...
Identify first if it is a "screw on back" or a "pop off" back. Screw on backs have multiple indentions on the caseback where a special tool fits in the grooves to twist it on and off. If it is a screw type back then you will either need to buy a pricey caseback wrench or take it to a jewelry store that changes watch batteries.
A pop off back will have a smooth caseback with no indentions on it.
Most of these are "pop off" backs. to pop the back off get a very sharp blade and apply pressure at about a 30degree angle between the case and the caseback on the underside of your watch. From there you should be able to pry it and it should pop right off. Another way is to put a razorblade between the case and caseback, tap the blade with a small hammer (lightly!) and then pry the back off.
Oct 19, 2009 | Watches
Need to change the battery and take off the steel back of the watch
This may be a threaded backplate and removing it without the proper tool may cause some damage you won't like. Most jewelers will sell and install the battery for a modest price.
Mar 22, 2009 | Swiss Military Watch
Watches Logo
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
