Question about Epson Office Equipment & Supplies
Why won't my Epson Stylus DX7400 printer print card paper? Want to print business, birthday, etc. cards but paper feed will not take the card paper. Can you please help?
aicaxz
  • 511 Answers
SOURCE: Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Posted on Jun 30, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
jimmy_k8
  • 242 Answers
SOURCE: how do i change the ink cartridges on my epson
It is as simple as below.
Open up the hood of your printer.
Switch on the printer.
The cartridge will come in the centre to remove.
Press at the back of the cartridge and slowly remove it.
While installing the new one follow the reverse process.
Thanks
Jimmy
Posted on Apr 29, 2010
SOURCE: Epson Stylus DX7400 - Ink cartriges
Dead easy if you follow these instructions:
Click on "Start" and select "Control Panel"
From Control Panel, select "Printers & Faxes"
Right Click on "Epson"
Select "Printing Preferences"
Select "Maintenance"
Select "Ink Cartridge Replacement"
The cartridges will now be easy to remove and just follow remaining instructions on screen.
Posted on May 10, 2010
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus cx5 series
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper not feeding
This could be caused by several parts, the most likely is the paper eject sensor lever & spring being out of position. Get a stiff piece of A4 card such as the backing from a note pad. Make sure the print head is in the parked position (fully right). Position card in the feed hopper and push through the feed mech. Open the top and watch for the card to come through the printer. This should realign the lever and also clear any obstructions in the paper path. Always try to remove paper jams in the direction of the paper feed, pulling backwards can damage levers etc.
Please take a moment to rate this solution. Thanks.
Mar 08, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Uneven paper feeding
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper feeding
I beleive it is the paper thickness lever on the right side when you lift up the scanner section.
Here is the setup guide:
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
Please remember to rate Techs who assist you for free :)
Joe
Sep 12, 2008 | Epson Stylus CX6600 All-In-One InkJet...
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
