Question about Whirlpool Duet GHW9150P Front Load Washer
Washer shakes I've been fixed the level front and back several times and the machine still shaking, I noted the drum inside is not even when rotates. is this normal?
  • Anonymous Mar 31, 2014
    my duet washer shakes violently during high speed rotations, as if the 4 springs aren't serving any purpose. Is there something else it could be?
  • 1,036 Answers
If the drum moves about wildly during use, then the chances are the dampers need replacing.
These are exacly like the shock absorbers on cars (only smaller) and reduce the vibrations from the drum.
Without them, and just relying on the support springs, the drum will bounce about untill it breaks a hose - often banging the sides during slowing down from a spin.
It is also possible a support spring has come off or broken - this will cause the drum to sag when first loaded.
Both are replacable items with the back / top off.
Posted on Jun 27, 2008
  • 246 Answers
The biggest thing to look for on front load washers is not weather or not they are level, but more weather or not all 4 feet are firmly on the floor. Even if it has been set up by a company for you, you can usually get less vibration by follwing these steps. 1 - Once you have it level, rock or wiggle the machine from the front right corner to the rear left corner back and forth. Repeat the same between the front left and right rear corners. you should have the same amount of movement both directions. 2 - Make sure your washer legs are "locked". The washer legs are like threaded bolts. There are nuts on the legs that must be tightened up against the bottom of the machine (or pedestal) to support it. 3 - if you do have a pedestal, make sure the screws between the pedestal and the bottom of the machine are tight. Loose screws will make the machine rock more. 4 - Open the bottom panel by removing the screws at the bottom of it. There should be 3-4 (depending on the model) shocks. Make sure they are all attached to the bottom of the washer and to the white tub that holds the water. 5 - Tighten the frame screws. (All of the screws on the back panel and the screws along the bottom panel). Most all of these steps are explained in the instalation manuals or the machine (and pedestal if applicable). However there is another posibility. If the machine is not sat on a soild floor it will also vibrate more. I have been into brand new and very expensive homes that did not have very much support in the laundry room floors. Top check for this, watch where the feet meet the floor. If the floor is moving along with the leg, there is a lack of support. The owners manual educates securing a 3/4 inch peice of plywood to the floor. I hope this helps. Reply back if you're still having trouble.
Posted on Jun 16, 2008
Wash shakes on the spend cycle
I would check to make sure the washer is level, the drum sounds like it's not spinning evenly and if the load isn't unbalanced it might just not be level front to back and side to side.
Mar 01, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
WE have a maytag preformer wash machine. Model #PAVT234AWW serial#10099602cv. The washer is level, but it still shakes bad when washing clothes, even after adjusting the load several times
Lift the top frame and check the grommets the suspend the drum, Open the lid and get a good grip on the front inside by the drum and give a good **** to open the top frame, the four grommets should be visiable in the corners. check to see if they are tight, if not replace them.
Feb 09, 2011 | Maytag Washing Machines
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Feb 24, 2009 | Frigidaire Washing Machines
My Washing Machine "Walks" Across the Floor, is there anything i can do to fix it? I HAVE THE SAME PROBLEM. THE WASHER IS ON THE 2ND FLOOR, FRONT LOAD WASHER WHILPOOL, AND HAS BEEN LEVELED SEVERAL TIMES....
2 thing ifyou remove the lower acxess panel(3 screws acros the bottom) yo can look inside and make sure the 4 suspension/shock absorbers are in place. if they are yo can installa new product to minimze the shaking ofthe frontloading wsahers, reallly has improved performance on the machines ive tried it on..
Jan 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WAY too much shaking
Take out the four "shipping\travel" bolts in the back of the machine. Read the manual- it will tell you how to do this. John
Apr 29, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
290 people viewed this question
Dan Webster
Dan Webster
Sal De
