Question about DeLonghi DE400P Dehumidifier
DH400P pump is not working, please advise, thanks.
  • dbpactman Jul 03, 2008
    Pump stopped working. It sounds like it is when I put the pump to the on position, but still when the pan fills up the machine starts beeping and shuts down. This happens whether the pump is in the on or automatic position. I tried to blow out the line to make sure water could be pumped through the drainage tubing. It is flowing if I blow into it or by gravity. I don't know what else to do. Please advise.
  • nm156 Sep 04, 2008
    I had the same problem and followed the advise here.
    It wasnt an easy task , but I would think any one with a screw driver and memory to remember which screw went where can do it.
    You pretty much have to remove the entire cover off the unit.
    The small tank inside was filled with water and gunk. Simply remover the water, gunk , clear out the water lines , screw the cover back on your done!
    Many thanks for the advice,
    I was getting tired of emptying the tank in the middle of the night.
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Posted on Jul 21, 2008
  • flybynyt Feb 23, 2011
    Here are a few pointers I would add to Ladyfixer's great instructions:
    Tools: Philips head screwdriver; 2) Turkey baster, or my favotire little tool "The Mix-Mizer" handy to **** out the mucoid slime. 3) Needlenose pliers with cutter 4) small plastic ties to re-clamp hose connnections to pump, tank, etc. 5) tight fitting rubber gloves, the kind your doctor wears. 6) Pipe cleaners.
    Once all the outer case screws were removed (some wehre flat head, some not. take notes on which screws go where), I was able to flip the outer case open like a ****-shell. Rest/balance the digital control panel wiring connections on top of the unit without having to disconnect and remove. Once visible, you can follow the water's path and easily see how things get gunked up.
    The inner tank and float design is not unlike your home toilet. Once the float level reaches a certain hight, the pump kicks-in, and sends the water uot the bottom.
    DON'T try to pull the hose connections off without cutting the plastic ties or you will likely snap off the nipples. Once the ties were cut, it was easy to remove hoses and the pre-filter-backflow preventer, which was also clogged, chocking off water flow to the pump.. **** the mucoid slime out of the inner tank. There was A LOT, and it's gross. Once removed from the unit, I soaked the filter-backflow preventer in Efferedent and hot water. Once the sludge started to break-up, use the pipe cleaner and pressurized air to force the sludge out of the little nipple openings.
    re-assemble.
  • Lynn De Marco Jun 24, 2012
    I discovered that my pump was not functioning properly for the same slime build-up reason stated above.
    A friend cleaned out the slime in the pump tank for me last year and broke one of the nipples just as flybynyt mentioned below. I didn't see the inside before he fixed it and he sealed the hole up with epoxy so I'm not sure how the entire drainage tubing setup was plumped.
    To make matters worse, I just tried cleaning it again this year and I broke off the other nipple!
    I am ordering a new pump tank but I still need to know what drainage tubes to attach to the two drain holes, and where the pre-filter-backflow preventer should be inserted in the drainage tubing.
    As I'm sure everyone knows by now, there is no repair service manual available online (that I can find, at least) for the DeLonghi DE400P, only the user manual and a parts diagram.
    Would it please be possible for someone to post either a photo of the correct pump tank and drainage tubing/pre-filter setup or draw some kind of diagram? This would be a real aggravation saver!!!
What is the part/how to find replacement discharge tube for DH400P? I lost the original hose because, initially, I was able to just drain into floor drain. Now, new location, I need to use the pump feature...
Try explaining what you need to an appliance parts supplier or find a current model DeLonghi dehumidifier and identify to a salesperson what you need.
Jun 12, 2014 | Dehumidifiers
I have a De Longhi 8C70 Dehunidifyer. It is approximately seven years old. The pump is broken, when I flip the pump switch to the on position, the water no longer goes through the tube but drips into the...
Think the problem is with a clogged tube running to the drain, rather than a faulty pump.
To test this theory, first turn the unit OFF & unplug it. Using an 18" long, appropriately sized, plastic Zip Tie. Carefully insert it into the drain hole tubing and continue to push it in unitil you reach a bend in the tubing. Gingerly work it past this bend until the Zip Tie bottoms out or your run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will help break up any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Plug the unit back in and turn the unit ON. Set the control to Pump Mode and monitor the drain for water flow.
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | DeLonghi DN40G Dehumidifier
My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 29, 2011 | Haier 45-Pint Dehumidifier
The dehumidifier is not taking the water out of the air. It runs fine but there is no water in the bucket and the humidity meter is still reading the same number. This has been going on for 3 days now....
heatman101
0-==
Oct 01, 2010 | Danby DDR2509EE Dehumidifier
Delonghi DH400p dehumidifier running but not collecting any water ? Humidity is 68 set to 50???
Hey, I had the same thing with mine.
First, try cleaning out your filter if you haven't already. It gets angry if it can't get any air.
If not, I don't know how brave you are, but I ripped mine apart to fix the problem. I took off the panel with the filter (5 screws) and you can see a collection tray with another little collection gutter under that. Both of mine were filled with junk, mostly dust that had gotten wet to make this awesome disgusting sludge. If you can get at it from there, try to clean the sludge out of the collection tray and the little gutter. I ended up taking my whole unit apart so I can get the collection tray out (dumb design, you have to take apart the whole dang casing to get at two screws that hold the collection tray in).
May 14, 2010 | DeLonghi Dehumidifiers
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Error code E3 on delonghi dehumidifier DH400P
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
Delonghi DH400P Discharge Hose
I have the same problem on ocassion.
I just remove and reseat again , making sure the front of the tank is flush with the unit. sometimes a little more push in does the trick
Aug 11, 2008 | DeLonghi DE400P Dehumidifier
Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Jul 11, 2007 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
1,991 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
