Question about Dryers
Heater not heating up, keeps saying clean filter all filters r clean plse help,
    President:
  • 3,074 Answers
You will need to disassemble the dryer and clean out all the lint, under the screen there is a sensor, here is a website that should assist in the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Posted on Nov 07, 2010
Error code cfh
cfh is not an error code. it stands for "call for heat". back wash the pool filter. check continuity of pressure switch to ensure it is closing at proper pressure. jump pressure switch and if heater fires, there lies your problem
May 03, 2013 | Raypak Pool & Spa
Filter alarms when filter is clean
I purchased and installed my GE Hybrid Jan 2013. Several days after the install the "Filter Check" beeper/LED started. I reset it and it keep kicking in. I took a peep under the covers and discovered the T5 sensor was laying on the floor pan near the compressor. There is a hole in the 240V box, above the evap coils. I attached the T5 sensor there. At least from a diagram perspective it match the location for the T5. fast forward to Aug 12. The filter beeping/LED start again. There was a "little" dust on the filter. I cleaned it and it went two days and came back. I started the diag and T5 looks good (75 degrees). I put my HVAC temp probe on the compressor in. Matches 76 degrees on my probe. The compressor out, not so happy. The diag (E4) says 131, my probe says 158. Me think the GE Sensor is funny or the GE computer/program does no how to "tell time and temperature". I'm going to button it up and see what happens. It probably going to be a GE service/parts call.
Sep 16, 2012 | General Electric Ge Appliances GEH50DNSRSA...
Split a/c. RAS/RAC-35YHA3 1. Book says Green light on, filter needs cleaning. Filter and air way clean. ?? 2. Heat function ok, Cool function ok. Auto, heater comes on and keeps going. I swictched back to...
I believe the filter light is just a timer set for "x" any days or month. Most t-stats are that way. If you have the manual, you can reset it. Also make sure fresh batteries are in the controller. Good luck.
Apr 05, 2011 | Hitachi Heating & Cooling
My heater is flashing filter and itis clean and the number 14 is flashing as well whats going on?
The 14 code is for an over heat. Even if the filters are clean you may have to look at the fan itself. Make sure the louvers in the front are open to let the air out of the cabinet.
Keep us posted,
Tom
Oct 22, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Little to no heat where is the filter i want to see if it needs to be cleaned?
Their is no filter on the heater, your pool filter. If it is dirty your flow rate will go down and without enough flow the heater would overheat, but for a pressure switch in your heater. So if you clean your baskets, (pump and skimmer) and clean your filter this may help. Without more info this is all I can tell you.Hope this helps.
Jan 17, 2010 | Pentair Minimax NT Heater
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
Says clean filter strainer
Could be the pressure switch on the heater. Jump switch. If heater fires the switch is bad
Jul 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
