Question about Maytag Performa PAV2200
The agitator doesn't work on the wash cycle--it will empty and spin on the rinse cycle! I checked the belt and the agitator splines and they are all o.k.
  • Ricksgamer Nov 10, 2010
    problem fixed--thanks
  • 4,323 Answers
Hi
Please make sure that motor is running fine and it is not jammed. If the motor is fine and moves freely then check the selector switch for any disconnections. If the selector switch is fine then you'll need to replace the timer. To disassemble the timer please unplug the washer. Remove the selector knobs by pulling straight off. Remove the 3 screws that secure the rear, top edge of the frame assembly to the end caps and rear shield. Pull the frame assembly forward and lay it on a cloth. To remove the timer knob locate the hole with the timer knob shaft at the rear center of the timer. Using a small flat blade screwdriver, pry the rod located in this hole up to release the timer knob. Knob and skirt can now be pulled off. The timer is locked into the control shield with the tabs. To remove the timer remove wiring harness plug, remove the screw and pry the tab located on the center of timer, slide it towards inside of machine. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Nov 07, 2010
2 Suggested Answers
SOURCE: The agitator doesn't work on the wash cycle--it
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=8
Hi above is a place to obtain for free your service and repair manual, here there are troubleshooting steps to be performed to isolate the problem(s)
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/
Above is a great DIY washer site to assist you to isolate and repair your problem.
Any grinding noises are NOT good, and if the belt is OK, then we must suspect something maybe caught in the pump, or a bad pump or gearbox? It's pretty hard to tell just from a description, well unless the description is unique, but noise can mean many things.
Now, if you don't wish to DIY then simply call in a Maytag serviceman, and then when he arrives ask for a "Quote" before allowing any work to be undertaken. This way you can make an informed decision as to what to do, repair or replace, depending on costings.
Posted on Mar 20, 2011
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My hotpoint washer will spin but will not wash or rinse, the agitator makes a noise as it attempts to wash and then rinse. the spin seems to work fine
The agitator shaft has splines at its top which fit inside a splined area inside the agitator. Sometimes the splines in the agitator strip; then you would need a new agitator. If that is not the case the problem is within the mechanism. There is a repair kit available for that, but you need to take the mechanism out of the machine. I am assuming that you have the "direct drive" machine, recognizable by the pump sitting at the front, in the middle, under the tub. If you have the older, belt driven washer, please get back and I will explain.
May 09, 2011 | Hotpoint Washing Machines
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
552 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
