Question about Dacor DMO24SS Microwave Oven
Dacor dm024 microwave oven no power. nothing works, but power @ electrical outlet.
  • rwc1375 Nov 08, 2010
    do i remove all external screws to access the internal fuse? I have an ohm meter. I am a retired electrician and familiar with capacitors.
  • rwc1375 Nov 10, 2010
    removed cover, found blown fuse. what do I need to check to determine why fuse blew? I know how to use ohm meter.
  • Dacor Master
  • 43,501 Answers
Your microwave has a fuse inside that will cut all of the power if anything goes wrong....
Something inside there has gone bad and it blew the fuse....
The microwave will need to be torn apart and the problem found which can be difficult if you do not know how to use an OHM meter well...that tool will help you to find the short or the part that is pulling too much current...
Working inside microwaves can be very dangerous, so be careful if you decide to try it...
Here isa tip that will help you to figure out what is wrong with your MicrowaveOven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 07, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 08, 2010
    Yes, the outside cover needs to be removed and where the power enters there should be a fuse..
The Dacor DMT2420S microwave has power. Instrument dial is lite and the timer works. I can program the keypad however the turntable will not turn and the microwave will not work. The timer will count down...
There's no reset button, and if the fuse were blown, the oven would be totally dead.
Your problem is almost certainly a failed secondary interlock (bottom door switch) or its mount.
You can see our help file on door switches here and the service manual here.
Jun 20, 2011 | Dacor Microwave Ovens
The MW died. No power or lites on panel.It will not work.Could this be a panel replacement like on the JennAire range?
Welcome to Fixya Support,
It seems to be problem with panel and before concluding make sure that your Micro Owen Power supply cables and power outlets are working or not. If all are working fine,it is deffinately problem with HV powersuply and Magnetron.
I think it helps.Let me know.
Dec 22, 2010 | Dacor DCM24 Convection/Microwave Oven
No electricity Clock is off nothing works
Plug something else into the outlet and see if the device works if it doesn't then reset the breakers. If the other device does work then the microwave is bad and needs replacement.
May 29, 2010 | Whirlpool MH7140XF Microwave Oven
Dacor Microwave Touch Screen lite but blank
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here and replace it yourself for just over a hundred.
Sep 29, 2009 | Dacor DMT2420SS Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
When i plug my microwave into wall outlet sparks come out of the outlet and now none of the other outlets in the kitchen are working. There is also a charring on the outlet and the prongs of the microwave...
Well, the breaker has trip,but the microwave must have a short in it.Go turn turn back on and don't plug the microwave back into it to see if everything works.
Mar 14, 2009 | Dacor DMT2420SS Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMO24SS Microwave Oven Logo
237 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
