I need to get two access codes for my Bernina V3 Software. I have parallel port dongle but need the codes to complete the reload of the software to another computer.
  • 13,433 Answers
Hello
product keys can only be purchased from a reseller or directly from the company, fixya can not give out any serial keys to you, that would be illegal.
Posted on Nov 07, 2010
How to repair a bernina hasp lock
HASP or security device dongles were used on earlier Artista software. If your machine still has a parallel port and the HASP devie is on the connector then you probably upgraded windows over time. There is a XP device driver fix you may need to install. I recently loaded the ancient Artista software into a modern machine so I know it can be done. Just need to have the proper hardware support.
If all your trying to do is communicate with the machine from the PC then look into an USB to SERIAL converter and use the Artlink software from Bernina (free). Has much of the function that the earlier software did except for limited edit capabilities.
Jan 02, 2011 | Bernina Artista 180
I ve a mac, how can I use Bernina software
Select and install virtualization software for your MacBook Pro. You can choose from several popular virtualization packages for the Mac, including Parallels Desktop for Mac, VirtualBox and VMware Fusion. VirtualBox is a free, open source software package, while Parallels Desktop and VMware Fusion are commercial software products
Install Windows within your virtualization software. You much purchase a copy of the Windows operating system if you do not already own it; it does not come with the virtualization software. Most virtualization software includes a wizard, or assistant, to guide you through the Windows installation. Windows will now run in a "virtual machine" on your MacBook Pro.
Install your Bernina Artista Embroidery Software on your virtual Windows system. You install software into the Windows virtual machine the same way you do on a physical PC.
Plug the Bernina security dongle into a USB port on your MacBook Pro. The Windows virtual machine acknowledges the dongle, and may ask you if the USB dongle is to be used with the Mac or Windows system. The dongle is a hardware device that provides copy protection for the Bernina embroidery software.
Run the Bernina Artista Embroidery Software by choosing it from the Windows Start menu
Dec 19, 2010 | Computers & Internet
USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Jun 23, 2010 | Bernina Artista 180
I have a reader-writer box for a Viking Rose machine that is missing the dongle. Is there any place I could get just the dongle?
The dongle is only available with the software when you buy it. The dongle alone doesn't run the reader/writer box. The dongle is the code key for the software that allows you to send designs to the reader/writer. So purchasing new software (which also gets you the new dongle) is what you'll need to do if you want to send designs to the programmable card. Another issue you may have is that the older reader /writer box that uses a parallel port hook up, doesn't work with the new software. So if you have an old reader /writer, you'll also need a new usb reader / writer box. The new reader / writer also comes with a new programmable card.
Nov 20, 2009 | Husqvarna Viking 1
I need to convert my parellel port dongle to USB
I have the same problem...V3 software. have not heard of an adapter. The software wouldn't work with Windows XP or Vista anyway. I upgraded to Editor plus V5 but have kept my old Designer plus on an ancient laptop so I can transfer old patterns. You will also find that your new laptop doesn't have a serial port to accomodate the old cable to bernina 180. Unfortunately it's always the case with updating a PC. Everything else has to follow! My advice, get hold of an old laptop:)
Jun 16, 2009 | Bernina Artista 180
Parallel dongle will not work with new system that only has USB connections
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Apr 16, 2009 | Computers & Internet
Cannot open Bernina Software - States Hasp not installed -100 -
More likely the software you have is a corrupt one or is not compatible with windows ME.
However, to be on a safe side, follow the steps :-
 1. Remove the dongle from the USB port.  2. Uninstall the software.  3. Restart the PC.  4. Download the software.
 Make sure that the software is compatible.
 Unless change the CD or download the software from some different website ( In case you are downloading it from a particular website ).
Thanks.
Mar 25, 2009 | Bernina Artista 180
New computer won't work with Artista software
You need a new security code. When we changed computers we worked with the dealer on where to send the form requesting Access code. You can find the form under Help on the far right of your menu bar. It's the last item called Access Code Order Form. They emaild it back to us with the code we needed along with the install instructions. The dealer should also be able to assist you with your laptop issue, although you may only be able to use the software on 1 PC or laptop as you are probably licensed for 1 copy, and they us the dongle to validate the software and the machine combination.
Best of luck.
Nov 20, 2008 | Bernina Artista 180
Dongle
Hello. No, the only way you are going to get this to work is to replace the software with new ones, as all software come with different dongle numbers. The dongle numbers are specifically for the software that you have, you can't even change dongles. Can you get in touch with the seller to give you the dongle? I have a set of Cracked software for the BERNINA ARTISTA 180 that I can copy for you for $200, which you don't need a dongle for. Email me on: lfr6@bigpond.com I have a BERNINA ARTISTA 180 as well and this is the software I run. RRP for the VERSION 3 and the CPS software is $4500.00. Thanks. Lawrence
May 02, 2008 | Bernina Artista 180
Computers & Internet Logo
David Payne
David Payne
