Question about Vizio Televison & Video
I have a Visio LCD TV 2 years old not working -- i have a backlight but not screen
About a year ago our visio tv started having lines going up and down from the bottom to the top. we called direct tv and they could not find anything wrong with the cable. the problem got better and then worse. finally we called the tv repair man and he said it was the monitor and that it cost more to replace the part than it does to buy a new tv. that means after about a year that we purchased it the tv monitor was bad. now what do we do?
Posted on Nov 29, 2010
2007 visio tv will flickerimage on and off why wont the image stay on?
if it's a fast flicker, you could either have a backlight inverter problem or power supply problem. The problem with 32" sets Hannah is that they are not worth repairing these days as the prices have dropped like a rock. You can spend more fixing the set than buying a new one! The fact that its a 2007 would make me want to purchase new. Your TV is 7-8 years old and is at the end of its service life. Sadly, LCD TV sets were not designed to last as long as the old tube sets. 5-7 year life expectancy is typical. If I have been of service to you please sign my guestbook page @
http://www.back2lifeelectronics.com/Guestbook.php
Jun 29, 2014 | Vizio L32 32 in. LCD HDTV
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
I have an lg 52LG70, 3 years old. recently, after i hit the on button, the tv will come on, but within seconds, fades to black, starting at the corners, moving to the middle. still have audio. a few...
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Mar 22, 2011 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
I have a 2 year old RCA L42FHD37 LCD TV. Sound is working but I have no picture, any suggestions?
Tv turn on now,does it have a flashes of pictures only few sec. than dies have sound left only?Yes,than those 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Dec 27, 2010 | RCA L42FHD37 42 in. LCD HDTV
I bought a phillips 32 flat screen 5month ago,and it has gone wrong,it works for 20 mins then the picture goes off the sound stays on
Tv is less than a year old call Phillips for warrenty repair.This tv have a 1 or 2 long boards,call the LCD inverter boards,it have problems,about to died.These 1 or 2 long LCD inverter boards are to help the LCD screen to have a backlight to produced a picture.That why u have dead pictures,but still have sound.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Sep 20, 2010 | Philips Televison & Video
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Visio 42in. Plasma TV
The TV is a Plasma, it does not have a "BackLight" as it were, that is for LCD's only.
Vizio are fobbing you off. It will need either a Y-Sustain & Buffers or a Z-Sustain.
Sep 06, 2009 | Vizio P42HD Television
While watching my 32 inch lcd hdtv the screen turned dark
Could be some bad caps in the power supply but also the inverter panel.
Aug 04, 2009 | LG 26LG30 26 in. LCD TV
Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
May 06, 2009 | Vizio VW37L 37 in. LCD HDTV
Televison & Video Logo
98 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
