Question about Microwave Ovens
I have an old Modern Maid electric double wall oven, the upper oven's lower coil no longer comes on when the oven is set to bake. The upper coil does come on, but the oven does not get up to temperature. I was just going to replace the whole oven but cannot find a match in regards to it's dimensions (24" wide x 39" high). I really don't want to remodel my cabintry just yet. Any solutions on either where to start to repair this unit or complete replacement (wife would prefer a white unit and something not overly expensive). Turkey is only a few weeks away and I need to resolve this soon. Delaware Man
danforddan1
  • 192 Answers
SOURCE: microwave oven replacement Model#MWF307Z-3 Allegro series
You can look for parts here on FixYa,
good luck hunting, I have the same prob, with my Sharp convection M/ wave. I have been looking for 3 yrs. now and it only a 1982. Good luck DFD
Posted on Apr 15, 2009
MicrowaveSvc
  • 9149 Answers
SOURCE: My father's old Jenn-Aire microwave, Model # M170,
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Posted on Aug 20, 2009
Testimonial: "Thanks for the quick reply and helpful tip. I will follow up on your suggestion."
  • 1796 Answers
SOURCE: Jenn-Air Microwave Oven (JMC8130DDB) is
Hi!
I read your comment about needing to remove the control board to inspect it for damage. Looking at the diag. below, all you need to do is open the oven door and remove the two screws (#2 on diag.) fastening the brackets that hold the board in place and you can take it from there.
Refer to the diag. below If it was me, I would start by turning the breakers for both ovens OFF, then, in getting someone to help me pull the oven out, disconnect the power cord and check the power circuit protection devices like the fuse #4, located above the fan and the power board #25 also located on the back of the unit. Before replacing the blown fuse, inspect the wiring, If the unit is mounted over an oven that was in the Self Cleaning Mode that reaches temps. of about 500 degrees, there is a chance that a wire's insulation melted and shorted the unit.
If you need better resolution and the names and prices of the components on these diagrams, click on the following links: for the first diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00001?blt=06&prst=0&shdMod=JMC8130DDB for the second diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00004?blt=06&prst=0&shdMod=JMC8130DDB
I hope this info is helpful to you. If you need further assistance, just place a comment.
Posted on Mar 03, 2011
  • 36 Answers
SOURCE: jenn-air ww27430p double wall oven
that meens the clock is bad
Posted on May 12, 2011
heatman101
  • 43501 Answers
SOURCE: I have a GE Microwave/Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [[]
Posted on Aug 10, 2011
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
My electric lower oven doesn't get any heat.
Could be a lot of things, door lock switches, bad element, a fuse, the thermostat a broken wire or cold solder joint. etc
Good luck
Feb 20, 2014 | GE Profile 30 " Stainless Steel Built-In...
JT980 trivection double wall oven, some buttons are not working
If the control circuit board is clean with no signs of grease or moisture deposits, it's almost always the membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You can download GE owner's manuals and installation instructions here.
Jan 09, 2013 | GE Profile JT980 30" Built-In Double Wall...
Oven will not bake correctly when set to bake only the top element comes on
The problem is likely one of two things: Either the lower burner is shot and should be replaced, or there is a defect in the switch. The burner is the more likely problem if the upper burner is still working. If the lower burner works on any of the other settings it could be the switch, which would need to be replaced.
May 03, 2011 | Microwave Ovens
I have a Thermador ME272 double-convection wall oven. After self-cleaning the bottom oven, the bottom oven won't turn on. When I press Lower Oven or Self-Clean on the control panel, I get no beep and...
I would almost guarantee the thermocouple is bad.It is a small rod whose wires come out from the back wall into the oven and is mounted inside the oven,usually near the top.This is a common fail component in ovens due to the temperatures it endures over time,especially with self-cleaning because they usually go over the maximum temperature cooking allowed during cleaning.If you want to test it yourself,you or someone can swap out the 2 thermocouples as they should be identical..Make sure the circuit braker is pulled first.Behind the oven there is probably a cover which is fairly easy to access.If it is possible to switch the 2 connectors without removing the thermocouples,it would obviously be much quicker.If you switch them and turn both ovens on,the problem should switch ovens also.If you switch the thermocouples and the problem DOES NOT switch ovens,the bottom doesn't work but top still does,the circuit board is bad.Wait about a half hour before touching the thermocouple after heatup and leave the door open.Good luck,Greg
Nov 20, 2010 | Microwave Ovens
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Microwave Ovens Logo
117 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
