Question about Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE6800AYW shows error DO (Door Open?) bu the door is closed and the machine would not turn on
    President:
  • 3,074 Answers
Door switch, it is located inside the dryers front panel, there are a total of eight screws to take the front panel off, hinges have four and lift up an out, the other four are on the opposite side there are white plastic fillers(this is for door reversal), the panel lifts up and out. Here is a website to check the switch, may have a broken keepers,loose/broken wire or just a bad switch. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Nov 07, 2010
Od error code
The Neptune Od code will come up when the unit does not see the door opened before starting another cycle following a completed cycle. Simply opening the door and closing it again will remove this code until the same incidence happens again. So if you are looking to rewash a load of cloths you must first open the door then close it before you can start the machine over. Pleazer Appliance...
Apr 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't start. Display shows "od"?
od is an open door error if the door is closed then you would have to replace the door switch or the wiring that goes to the door switch first try to open and close the door and make sure it seats properly in the small hasp type holder if the error code still persists then check the wiring to the switch and if the wiring looks like everything is connected well then you would have to order a new door switch i hope this helps in your appliance situation and please remember to rank this solution if you have any more questions please message me back. Have a great day
rickead1
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer has an error code "do" What does this mean?
The washer detects that the door is open when
starting a cycle or the door is not locking.
Close the door tightly and restart the cycle.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
I am getting error code d0
do code = door open, close the door and restart the washer...if "do" error code does not clear when door is shut, door switch will need replaced
Please rate this solution
Jan 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Excellent, glad to hear we could help.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MDE6800 Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
