Question about Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator
Can not remove the double doors of samsung rf265aabp modl
    President:
  • 1,961 Answers
Hi!
I hope you have the guide to remove the doors of your model. And that you follow correctly these steps
1. Using a flat head screwdriver, gently pry off the door latch bezels. A door latch bezel is illustrated on the left image. (Important not to break off the lock tabs on the bezel on the right image)
2. Remove 3 screws from can not remove the double doors of samsung - alpug_2.jpegr.
3.
Lift the top cover up. Disconnect both door switch connectors, and then gently pry out the ambient air temperature sensor. (See second picture below can not remove the double doors of samsung - alpug_3.jpegnd door switch and temperature sensor location.can not remove the double doors of samsung - alpug_4.jpeg>alpug_3.jpeg
4. Disconnect the two electrical connectors on the left hand side.
5.
Disconnect the water line by pushing in the release tab towards the connector housing, and then pull the white water line out of the housing.
On both hinges, remove the screw holding the green/yellow ground wire using a # 2 Phillips screwdriver, and then disconnect the green/yellow ground wire from the hinge assembly.
7. Remove the three 10mm hex head bolts, and then remove the upper hinge.Repeat for the other hinge. (Warning: Have an assistant to support the door before removing the bolts. The door is heavy and can fall.)
8. Lift the door off the lower hinge and remove.
Posted on Nov 07, 2010
Where can I get a repair manual for my Samsung model RF265AABP French Door Refrigerator. Could you send me a link to where I might get one?
Go on Ebay or Amazon and see if a repair manual is available. Even if you have one, this repair is beyond the ability of the average person.
May 05, 2014 | Refrigerators
Samsung rf4287hars control panel blinking
This could be a temperature sensor problem. My RF265AABP model had a broken ice maker temperature sensor wire that caused it to read 88 88 with the last 8 blinking. See my detailed posts under this model for more info on diagnosing it.
Aug 11, 2013 | Samsung RF4287HA
Control panel blinking
Broken wires at the ice maker temperature sensor can cause that problem. See my detailed posts under model RF265AABP for more diagnostic info and my solution to the problem.
Aug 11, 2013 | Samsung RF4287HARS French Door...
Samsung french door fridge, bottom freezer
It might be a power supply problem. My RF265AABP model has +5V and +12V from the power supply board located in the compartment with the control board.
Jul 09, 2013 | Samsung Refrigerator PCB Board -...
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
Jun 29, 2013 | Samsung RB217ABPN Bottom Freezer...
What do the flashing blue lights mean on front of refrigerator?
Flashing blue lights on front of what model Samsung refrigerator?
Jun 12, 2013 | Samsung Refrigerators
How to replace samsung flex-tray ice tray
On my model RF265AABP, it is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out. Yours may be different.
z
Ice maker assembly upside down on bench.
Apr 10, 2013 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
Not making ice
Check the ice maker temperature sensor. Mine (model RF265AABP) falls out easily and sometimes the wires break, causing the digital readout to read 88 88 and flash.
Mar 14, 2013 | Samsung RF263BEAESR 26 cu.ft. French Door...
Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator Logo
370 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
