Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My epson stylus sx 115 will not print in black. I have cleaned the nozzles and the print heads, all cartridges are full, I have removed the cartridges and recharged the ink, and still not printing in black. Any ideas?
  • 249 Answers
SOURCE: Hi, I have an epson stylus cx6600 , I replaced the
Did you put a new cartrige the first time, or just put ink in the old one? Ink cartriges dry out. If you let them sit for extended periods of time, you don't save ink, you let them dry out. You can try to bag and wrap them if you are not going to use for awhile and see if they keep longer...but usually you just have to get a new one. I've heard you can put tape over the end of it to keep it longer...don't know from experience though. New carts will usually do the trick though.
Posted on Jan 12, 2010
Soulvisitor
  • 1113 Answers
SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
Posted on Nov 04, 2007
MerlinTech
  • 197 Answers
SOURCE: Black ink not printing...
same on a test page?
Posted on Jun 16, 2008
  • 3 Answers
SOURCE: Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
Posted on Dec 29, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
Printer worked fine until yesterday changed ink cartridges now black wont work tried all options
Hello
well changing the cartridges will not effect anything to the printer but the duration taken for replacement will. As in epson if you leave the printer without cartridges will clog the head nozzles. Did you remove the cartridges and turned off the printer and left idle for sometime? if yes then follow the instructions below
1. Print nozzle check test print to know which nozzles are not working
2. Head cleaning from the printer software.
3. Perform step 1 again to see the difference after cleaning
IF NO
Then you have to take the print head out of the printer and clean the nozzles by using hot water in the Syringe and blowing the derbies out of the nozzles.
Jul 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus C88 won t print color ink black is
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus CX7400 Black ink won't print
You are a ******* and I WILL NEVER BUY A PIECE OF **** EPSON AGAIN...THESE PRINTERS ****
Jan 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge assembly not going to correct posy to replace black
Remove the cartridge and put it back in. If still it doesn't work, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the black pattern or no black appears at all, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing partial color no black
Did you remove the plastic protector on the ink cartridge before you installed it?
Nov 06, 2008 | Epson Stylus Color 1160 InkJet Printer
Epsom R340
print a nozzle check from the maintenance menu
see which colours are missing, run through a few head cleans and print another nozzle check see if there is any improvement
also replace the cartridges of the missing colour they may be dried up. have seen this before where a 3/4 full black cartridge just completely stopped printing
if the problem still persists then get a syringe or an eye dropper and some form of spirit (I have used vodka in the past but clinical alcohol is recommended as not as sticky)
choose change cartridges from the menu then remove the power cord. with the cartridges removed you now have access to the printheads.
using the syringe (or eye dropper) place the nozzle on the spike that goes into the cartrige and inject a small amount of the alcohol leave this to soak for a few mins then mop up the excess with a cloth repeat this a couple of times put the ink back in power up and run another head clean (you can also put afew drops on the spounge that sits under the print head during the head clean
print the nozzle check again you shoudl see most of the nozzles are now working run another head clean if desired now try with a pic
have used this on various epson printers including a stylus 700 R340 & 360
Jul 27, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson stylus photo RX500
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Apr 05, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus photo 830 my printer is only printing red wwith the word new zealand at the top
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Jan 22, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
953 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
