Question about GE DBL333GB Gas Dryer
My Gas Dryer stopped heating. Occationally after 5-10 tries in a 24hr period the heat will work for 10 mins. then cut out again. Is this a sensor problem or the heater part is not working?
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Nov 07, 2010
Testimonial: "A neighbor had a similar issue and that was indeed the problem and was replaced, the coil. TY for narrowing it down. Thanks much :)"
Dryer starts heats up but will not heat up again
WHAT TYPE GAS OR ELECTRIC? DOES IT STOP RUNNING TO OR JUST NO HEAT? IF GAS LOOK AT UR GAS SAFETY VALVE AND COILS? IF ELECTRIC CHECK THE CYCLING THERMOSTAT AS WELL AS THE HI LIMIT AND THE THERMAL CUT OFF, AND THEN ALSO CHECK THE MOISTER SENSOR. OR THERMISTOR
May 15, 2015 | Frigidaire Dryers
Error 61
Looks like E61 is a heat relay related.
Does the dryer heat OK?
Nov 26, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Lgq9030pqo start dryer ,everything normal gas kicks on starts heating., heats for a couple of mins then cuts out doesnt come on again drum keeps on going everything else is normal
Typically - when this happens - the gas valve solenoid is failed, and needs replacement.
The flame sensor (thermocouple) may also be the culprit if it is failed - it will not tell the valve there is a flame present.
Check those out.
Thanks!
Aug 23, 2011 | Dryers
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Dryer heats once or twice then stops heating
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001348.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 3-10 of the manual listed at the link below. Operation and replacement of coils is covered at page 3-32. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble. Good Luck
Maytag Dryer Service Manual
Sep 15, 2009 | Maytag Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
GE DBL333GB Gas Dryer Logo
154 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
