Miele Blue Moon Bagged Canister Vacuum Logo
Posted on Jun 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele vacuum cleaner hepa tt2000 blue
The suction is too strong and I can't regulate the suction with the rotary selector, it is constantly on high.
Anonymous
Level 3:
President:
  • Master 1,673 Answers
  • Posted on Jun 17, 2008
Anonymous
Master
Level 3:
President:
Answers
1673
Questions
Helped
704394
Points
3439
Is there a valve on the handle, near the tube or right on top by the switch that you can move to allow for less suction?
tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
Blows hepa filter from mounting
I have seen generic filters do this. Be sure to use original Miele filters. The generics are a few dollars cheaper to buy but you end up with an inferior quality filter that could cause other problems by continued use. same is true with bags.
A clogged filter may also do this. Miele vacuums are very tightly sealed, the exhaust air has to come out. If the filter is clogged, the pressure could pop the filter out, HEPA filters are suggested to change out about every 50 hours, for most people this is between 1 - 1.5 years.
We had a Miele come in for service the other day with the same complaint, installed filter was a generic, customer said it was a new filter just installed. We replaced with an original filter and problem ceased.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Failure of miele vaccum cleaner TT2000. Warning light comes but no power when pressing the power button
the vac filters are blocked it will shut off the power untill you clean the filters or replace
Oct 15, 2011 • Vacuums
2answers
My parents have a miele vacuum cleaner model s538. Do you know where I can obtain a repair manual for this vacuum cleaner. It is always on the "fritz". The vacuum has been taken for several...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://m.miele.ca/OperatingInstructions/en-CA/Vacuums/Previous%20models/Miele%20Vacuum%20Cleaner%20Manual%20S500-548_S600-648.pdf
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
1helpful
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
3helpful
My Miele Silver Moon "Reset" light is blinking. What do I do?
Greetings from GoVacuum,
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
