Question about HP Officejet Pro L7680 All-In-One Printer
Error 351 - HP Officejet Pro L7680 All-In-One Printer
My printer won't pick up incoming fax calls
Posted on May 03, 2011
  • 857 Answers
The reason for this error code is :
•The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
•The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
•The remote user pressed the Stop key while the reception was in progress.
•Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions what you can try :
•Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
•Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed
For more details you can check this link out :
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549&lang=en&cc=us&taskId=101&contentType=SupportFAQ&prodSeriesId=351105&prodTypeId=18972#Error344
Posted on Nov 07, 2010
Buna ziua am si eu un tel nokia X3-02 si nu merge, cind bag o cartela in el imi spune (enter restriction code) ma-m tot uitat pe net si nu ii gasesc un cod de deblocare, tel la-m primit. este adus din...
Bun? ?nseamn? c? telefonul mobil este blocat la re?ea, ave?i posibilitatea s? debloca?i telefonul mobil prin coduri debloca .. mod sigur cea mai buna si de deblocare este de coduri debloca ?i cererea mea personal? este c? nu merg pentru programul de deblocare, deoarece, uneori, software-ul s-ar putea ob?ine corupt ?i poate datele dumneavoastr? vor fi pierdute din cauza c? ?i, de asemenea, dont du-te pentru deblocarea gratuit, deoarece codul generat de circula?ie pot merge gre?it uneori, sa-mi experien?? nepl?cut?, a?a c? am mers pentru deblocarea de codurile din superunlockcodes ?i unlocked.you pot ?ncerca prea dar se vedea ?n acest dac? ?ara dumneavoastr? ?i furnizorul este listat .. deoarece pentru unele servicii sunt disponibile numai coduri .. verifica cu faptul c? ?i ?n cazul ?n care furnizorul de ?ara dumneavoastr? este listat, apoi ob?ine coduri ?i de a debloca telefonul mobil ..
Sep 21, 2011 | NokiaFree Unlock Codes Calculator
Windows live wont sign in, getting 8e5e0247 error, how do i fix it?
Hey Kidd... I don't know if this will solve your problem, I found it in a Microsoft Forum:
Anyone recieving the 8E5E0247 Error trying to login to Windows Live Msgr and/or Windows Update who has an INTEL processor & Hard Drive over 300Gb must install the Intel Rapid Storage Technology Software. This will solve your problems.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=19607&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel%c2%ae+Rapid+Storage+Technology+(Intel%c2%ae+RST)&lang=eng
Windows Live Messenger giri? yapmak yada Windows Update kullanmak isteyen fakat 8E5E0247 kod numaral? hatay? alan, Intel i?lemcili ve 300 GB ?zeri kapasiteli harddiskli bilgisayar? olan kullan?c?lar?n Intel Rapid Storage Technology yaz?l?m?n? bilgisayarlar?na kurmalar? gerekmektedir. Bu yaz?l?m ya?ad???n?z problemi ??zecektir.
indirmek i?in:
http://downloadmirror.intel.com/19607/eng/iata_enu.exe
Aug 12, 2011 | Computers & Internet
I am trying to send faxes and keep getting error 351* what is this?
How to easily fix (error 351)? There are two (2) ways to fix 351 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 351) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
hope this helps..pls rate if this helps thanks
Mar 21, 2011 | HP Photosmart C7180 All-In-One InkJet...
Error 351
  • The following is for error code 351
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed.
Mar 01, 2010 | HP FAX 1250 Fax Machine (Black)
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
I cam robo 351 driver 4 free
I have found driver files for ROBO-351 usb camera, Please follow the below linl. Select category as camera and model I-ball Robo-351. Download both zip and rar files. Unzip the zip file and you will find setup.exe file. Connect camera and run setup. Your camera will work.
http://www.iball.co.in/Download.aspx
Thks & Regards
May 17, 2008 | Cameras
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
HP Officejet Pro L7680 All-In-One Printer Logo
953 people viewed this question
Seeker5211
Seeker5211
