Question about OKI C3400n Laser Printer
I can't print. Error says paper size or media type mismatch in tray. What can I do to fix the error?
Soulvisitor
  • 1113 Answers
SOURCE: Error message 490 mismatch
mismatch occurs when printer paper settings and document page size are not the same, check document page size.check print driver settings.
Posted on Nov 21, 2007
SOURCE: paper mismatch
you have to load the printer driver for HP Deskjet 990c. This worked for me perfectly and I'm sitting here printing my wedding invites right now! Good luck!
Posted on Jun 15, 2008
SOURCE: OKI B4300 Change paper
please keep the papers correctly aligned so that the sensors will recognize it...
good luck!!!!!!
dont forget to rate this
Posted on Aug 21, 2008
jonb3838
  • 237 Answers
SOURCE: I am trying to print
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
Posted on Feb 11, 2009
  • 253 Answers
SOURCE: Print error
Power off printer, unplug AC power cord, and hold down power button for 30 seconds, release, plug back in and let us know
Posted on Mar 29, 2009
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Paper mismatch displays on the printer. I have to pick the paper size manually on the printer to print. How do I stop this error?
Make sure that the paper size of your document, and of the tray are set the same - if there is any conflict you ned to resolve it each time.
Jul 01, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Will a ricoh printer automatically print once paper has been replenished
Short answer: Yes.
Long answer: As long as there was no other error or problem, if you send a print job and the tray it wants to pull from is out of paper, then as soon as you put paper in the tray and the printer recognizes the paper, it will resume printing.
(If you put in paper of a different size or type than the paper the printer is looking for, it will display a mismatch error and won't print until you tell it to continue or form feed.)
Jun 15, 2010 | Ricoh Aficio AP610N Laser Printer
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Konica Minolta paper mismatch problem
make sure that you specify the same paper size in the print dialogue window - i.e., in MSWord go file - print - properties - and make sure paper size in the dialogue box matches media type in printer tray
Mar 20, 2009 | Konica Minolta magicolor 5430 DL Laser...
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Printing index cards on oki printer
i changed the settings on media to rough paper & made sure all paper was to come from mp tray, but it does jam frequently, and every time it does, i need to open & re-open the front cover to get it to clear the error that appears. the error reads mismatched paper size, as there is not a custom size of small index cards of 3.5 x 5.
Mar 06, 2008 | OKI C5500n Printer
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
OKI C3400n Laser Printer Logo
855 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
