Question about Whirlpool GU2400XTP Built-in Dishwasher
Clean light is blinking
The clean light is blinking and it says to call for service
  • 413 Answers
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Posted on Jun 15, 2008
5 Suggested Answers
ngafm
  • 166 Answers
SOURCE: CLEAN and LIGHT WASH lights blink
peace,
Cut the power from the breaker source for 5 minutes. And it should reset the system!
Other wise you need hands on service
Posted on Sep 07, 2008
konzzz
  • 255 Answers
SOURCE: blinking clean light
if the unit is brand new,i suggest you should avail the warranty package that comes with your unit.
Posted on May 28, 2009
jsrock516
  • 5911 Answers
SOURCE: "Clean" light blinking...
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: Clean light is blinking. Services manual says:
Hi
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
Why does the oven cleaning light come on when i turn the oven on
Make sure that you slide the oven door latch all of the way to the left after the clean cycle. If the latch is still positioned to the right in the locked position then the CLEAN light will continue to blink. If the door latch lever is positioned properly to the left and the CLEAN light is still flashing then you could have a problem with the latch mechanism or the electronic oven control. You can try to reset the electronic control board by unplugging the range for several minutes (or shutting off the breaker for the range outlet) to completely disconnect electrical power. If the CLEAN light still blinks after you restore electrical power then you will likely need to have the range serviced by a technician.
Sep 09, 2016 | Hotpoint Kitchen Ranges
Blinking clean light, not completing cycles
some of the dishwasher have a device in them that you have to remove the container and clean it. mine is up side down cup that unscrews.
go to www.wikipedia.org
kenmore elite blink clean light
or go on to www.sears.com/service
talk to someone or look on line at
www.youtube.com/kenmore_elite_blinking_clean_light
see if anyone else had this issue
Mar 25, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
What does it mean when my clean light blinks but I cannot cancel or reset it
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
Jul 21, 2014 | Kenmore Dishwasher With Ultra Wash And...
Dishwasher won't start and the green 'clean light' is blinking
your computer has detected a problem , most likely with the water heating. its locked up. Try pushing the high tem wash buton and then the energy saver button , push them back and fourth a few times(some modles its 2 other buttons) This should actavate a service check cycle where all the lights go on. Let it do its thing, and cancle after a few mins. if it locks up again you need service.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light blinked and was reset and now nothing
Bearing in motor rusted on mine. We are working on it right now. Already paid $70 for a service call. They said we need a new motor. Just looking for the part now.
Aug 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
May 28, 2009 | Dishwashers
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
peace,
Aug 31, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
I have the kitchenaid dishwasher model #kudv03ctss0.the clean light stay blinking and when i hit the start it just blinks and then stops but the clean light stay blinking constantly.if i hit the cancel...
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
104 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
